Installation & Licensing
Member
wang13j
Message 21 of 35 (6,294 Views)
Re: softlock license manger error message
09-10-2012 10:20 AM in reply to: sbenda60
I am experiencing similar issues with AutoCAD 2013. The security problem occurs the first time I access the program after a reinstall. After another boot, the program suddenly closes itself while loading; this repeats indefinitely unless I reinstall the product, and then the cycle begins again. If it is relevant, can you clarify exactly how to change the neccesary permissions and location of the license files? It would also be helpful if you are familiar with the program closing itself.
New Member
GSMEDEIROS17
Message 22 of 35 (6,031 Views)
12-13-2012 12:33 AM in reply to: sbenda60
Awesome!!! it worked!! i found the "flexnet" folder placed in on the desktop and all Autodesk software worked like nothing had ever happened.  Wow, that was wild..thx.
Ps. using Windows 7
roadwayws
Message 23 of 35 (5,781 Views)
03-07-2013 02:31 AM in reply to: sbenda60
Still late
I tried this deleting the "above" files but go to start The "cad" program and it just shuts off. having said that all my other programs with the suite still work.
So I just cant use the AutoCad 2013 and have no place to put a serial number.
Any other Ideas?
thanks
New Member
caec-berlin
Message 24 of 35 (5,288 Views)
07-27-2013 09:08 AM in reply to: sbenda60
It also can be, that in the system configuration of Windows the Service "Flexnet Licencing Service" is deactivated (Window 7). If its activated all programms of Autodesk run.
Best regards.
Lena
New Member
chriscwhiteside
Message 25 of 35 (4,962 Views)
10-24-2013 07:06 AM in reply to: wang13j
I am having this same problem with Architecture 2014 on windows 8.1, and none of these solutions seem to work, can you help?
Member
p.j.luddy
Message 26 of 35 (4,930 Views)
10-26-2013 07:26 AM in reply to: sbenda60
Despite it working perfectly the first time around, I experienced similar problems with the Security system / Softlock license manager error when I was forced to reinstall my student version of Autocad Architecture 2014 on my new Windows 8 laptop. I tried many of the solutions that are spoken of here including attmepying multiple clean reinstalls and trying to deal with the FLEXnet files. However none of these worked until today when I spotted the solution to my problem on this thread.
It seems that all you have to do is:
                                                              1) Close any running applications or files or internet browsers
                                                              2) Cut the actual "FLEXnet" file ( found at C:\ProgramData )
                                                              3) Paste this file onto your desktop
                                                              4) Startup AutoCad and it should be running without issue
Thank you all for your help and in turn I hope this can solve this irriatating problem for anyone else who may be struggling with it.
prem
Message 27 of 35 (4,769 Views)
10-30-2013 06:47 AM in reply to: p.j.luddy
i am facing the same problems at one of our customer locations. none of the methods mentioned in the support and dicussion groups are working out Any solutions!! :smileysad:
Prem
Windows 7 64 Bit
16 Gigs of RAM
Intel I7
Nvdia Quadro 3000M
New Member
viniciosula
Message 28 of 35 (4,471 Views)
11-21-2013 10:00 AM in reply to: sbenda60
Buen día.
Instalé Autocad Civil 2014 con la licencia para estudiantes y me dice que la instalación está bien. Pero cuando lo abro el programa me sale un mensaje de "softlock license manager error messege" que está mal instalado. No se como resolver ésto, necesito su ayuda. Desde ya muy agradecido.
Saludos cordiales.
New Member
viniciosula
Message 29 of 35 (4,411 Views)
11-26-2013 10:54 AM in reply to: Jessup
Hola. Qué hago para resolver ése problema en Windows 8.1? Gracias.
New Member
princess16
Message 30 of 35 (4,101 Views)
12-24-2013 05:55 PM in reply to: sbenda60
I installed AUTOCAD 2013 and I've receved the soft license manager error.  I am running a stand alone Windows 8 pc.  I can't seem to find any solutions.  I've uininstalled, reinstalled, and used all of the different methods of installation that AUTODESK has to offer.  Does anyone have a solution for this issue?
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
