• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    sbenda60
    softlock license manger error message
    15808 Views, 22 Replies
    04-25-2011 05:00 PM
    I have installed the 2012 upgrade. When I open the program I get the following error:
    The security system (softlock license manager) is not functuining or is improperly installed.
    The program then shuts down. Any ideas?
    Please use plain text.
    Product Support
    Re: softlock license manger error message
    04-27-2011 07:21 AM in reply to: sbenda60
    Is this Autocad 2012 ?
    please try a clean installation of Autocad as admin
    http://usa.autodesk.com/getdoc/id=TS75218
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    Member
    sbenda60
    04-27-2011 08:04 AM in reply to: sbenda60
    I brought this to Autodesk tech. support. I have had issues with running 2011 Autodesk products. One day all was working fine. The next morning none of my autocad programs would run. After many hours of trying different suggetions from tech support we were about ready to re-format the hard drive and start new. When the 2012 update became available we figured one last try before the re-format. This is when the softlock error poped up. I recieved the following message from Autodesk in response to the softlock issue:
    "Softlock License Manager Errors were usually seen with the older version of AutoCAD products (releases older than 2008) and the typical cause of the error was restricted permissions on licensing folder or some corruption with the license file.
    The standalone license file location on Windows 7 is C:\ProgramData\FLEXnet and standalone license file name is similar to adskflex_00691b00_tsf.data and adskflex_00691b00_tsf.data_backup.001.  These files are encrypted files and basically keep activation information.  Please try giving Everyone full control permissions to the folder and move adskflex data files you find there to another folder (e.g. Desktop) and let me know if this helps."
    By doing this all of my Autocad programs work, even the 2011 products which started this process. After all the things we tried it seems it was a permission's problem. I have had many permission issues since installing Windows 7.
    Glad this one is behind us.
    Product Support
    04-27-2011 08:07 AM in reply to: sbenda60
    thank you for sharing the solution with the community :smileyhappy:
    Hashim Mundol
    Product Support
    05-16-2011 07:58 AM in reply to: sbenda60
    Thank you for posting that solution to the forums; it is the only one I have found for this error message in the 2012 products.
    Here are the paths for those files in Windows XP and Windows Vista, as well:
    On Vista or Windows 7:
    C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data
    C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data.backup
    On Windows XP:
    C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data
    C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data.backup
    Best regards,
    Jessup H.
    Support Specialist
    Product Support
    New Member
    john
    07-01-2011 12:14 AM in reply to: Jessup
    Having similar issues on XP but can't find "Application Data" folder with .data file in location specified.  Where else could it be?
    TravisNave
    07-01-2011 08:45 AM in reply to: john
    It's a hidden folder.  You can either turn hidden folders and files on within your explorer properties or you can put the path directly into your address bar and get there.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Contributor
    leaveAlone
    08-21-2011 05:49 PM in reply to: Jessup
    I am having this problem as well, however, I do not know how to give everyone full rights to these files on XP. Any help would be greatly appreciated. Thanks!
    jeff5509
    09-19-2011 08:25 AM in reply to: sbenda60
    I am experiencing the same problem with my autocad electrical installation. I am running XP SP3 and have ACE2011 and ACE2012. Neither will load and ACE2011 shows no error. The splash screen pops up and then goes away and nothing. ACE2012 at least lets me know that the softlock license manager is not functioning.
    I tried the fix suggested in the tread with no luck. Any other ideas or suggestions?
    Jeff
    jeff5509
    09-20-2011 10:08 AM in reply to: sbenda60
    So... if this solution doesn't fix the problem then what else could it be? I have found a few other references to other fixs for this problem but nothing is working. I have a stand alone license and can't get any work done. :smileysad:
