I'm installing my old AutoCAD LT 2002 and I no longer have the package that contained the serial number and key code, all I have is a random set of numbers below a bar code..... any idea how I can install?
You will need to contact Autodesk directly to see if they can provide the information.
This email may get a response: customersupport@autodesk.com
Also:
And you can try:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Good Luck!
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
