Installation & Licensing
rsu license cascading to Acad license
10 REPLIES 10
Message 1 of 11
708 Views, 10 Replies
Our network license is for 7 Revit Structural Suites 2014 and 2 Acad 2014.
We currently use 2012 ACAD and 2011-2013 Revit Structure.
8 computers access ACAD 2012 through a Revit Structure 2012 installation and Revit's ACAD 2012 shortcourt, and 1 computer  access ACAD 2012 through a regular ACAD 2012 installation. All are installations runs on a network license.
We typically run 2-3 Revits of different flavors (2011-2014) at a time and the balance of of the users run ACAD 2012. Lateley an error code-4.132.0. "a valid license could not be obtained by the network license manager" is given when a 8th or 9th users attempts to open ACAD 2012. The LMTolls shows 7 of  7 RSU used and 1 if 2 ACAD license used.  Does the Revit's ACAD 2012 cascade down to ACAD2012?
PS foru
10 REPLIES 10
Message 2 of 11
DarrenP
do you mean building design suite 2014?
this is an issue
http://upandready.typepad.com/up_and_ready/2011/08/autodesk-suites-building-design-suite-2012-doesnt...
DarrenP
Message 3 of 11
DarrenP
in reply to: DarrenP
you need to install autocad from the suite using the suite product key
DarrenP
Message 4 of 11
Current lic file is a combined with both ACAD abd RSU 2013.
Message 5 of 11
1 computer is installed with ACAD 2012 only for a light users. 8 computers are installed with RSU 2012. Some of the 8 computers have installations of RSU 2011 and or 2012.  The 8 Computers access ACAD 2012 through the Revit Suite installation. When the 8th or 9th. when the 8th or 9th computer tries to obtain a licens to use ACAD 2012 through the RSU 2012 installation we ger the error.
Message 6 of 11
DarrenP
what does the flex lm log say?
are they getting denied a license
DarrenP
Message 7 of 11
10:04:36 (adskflex) DENIED: "66000REVSU_F" rworrell@RWORRELLCOMP  (Licensed number of users already reached. (-4,342))
10:04:36 (adskflex) DENIED: "85792REVSU_2012_0F" rworrell@RWORRELLCOMP  (Licensed number of users already reached. (-4,342))
Message 8 of 11
DarrenP
are your users running multiple versions of revit on the same machine?
DarrenP
Message 9 of 11
One occurance of an Autodesk product per computer.  I run around the office, look and yell at the users if the use more.
Just install regular ACAD 2012 on my machine.  Regular ACAD 2012 will obtained a license. I closed out of ACAD 2012, clicked on Revit's ACAD 2012 Icon which resulted in a denial of license.
Message 10 of 11
DarrenP
try deleting or renaming this file:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13894457&linkID=9240657
DarrenP
Message 11 of 11
DarrenP
if the above doesn't work
the only other thing i can think of is were the revit suite license and the autocad licenses generated the same day?
DarrenP
Administrator Productivity
