Hi everybody i need your help to finish the revit installation with windows 8.1. when i clic on the revit icon the 3 first images appears and then go out.
Revit Architecture 2014 is not technically supported on 8.1. What I would recommend is that you install the latest service pack then try to run the Revit program in Windows 8 or Windows 7 compatibility mode as Administrator.
Good Luck!
