Hi
We run Design Academy 2010 at our Highschool and we are running into an issue because we have to re register every time a user logs into the computer.
We run a program called Deepfreeze and it resets everything that a user does to the computer each time the user logs off in order to save on disk space. We have tried registering the program as the default domain user account without luck. We have tried with Deepfreeze off and the user profiles took up too much space once we had a couple of users logged in.
Is there a way to enter the registration info once and then have multiple users able to log in?
Thank you
Brian
Could you specify which product you are refering to from the Academy suite.
What is the error you are getting.
If it is Sketchbook you can add the serial number to the HKLM instead of HKCU; (i can give you the exat hive if required)
