Installation & Licensing
re-installing on new PC
3 REPLIES 3
Scottgrove
455 Views, 3 Replies
How can I re-install my AutoCAD LT 2010 onto my new laptop when I can't find the disk?
3 REPLIES 3
philip.s
in reply to: Scottgrove
Hello Scott and welcome to the community.
Please use one of the following 72hr timed direct download links. Please note that for future reference, you can also request a media replacement or download link directly from this link.
AutoCAD LT 2010 32BIT
AutoCAD LT 2010 64BIT
Please accept as a solution if this fully resolves your inquiry, or feel free to reply with additional questions as needed.
Scottgrove
in reply to: philip.s
Phillip,
I was able to download and re-install my autocad 2010 LT on my new PC.  but...when I open the program it asks me to activate it.  I have entered the codes with an invalid response.
the codes that i have are
here is my case number from our last correspondence
Your Adobe ID:SCOTT@SCOTTGROVE.COM
Your Case Number:0183768392
Serial number: xxx-xxxxxxxx
Request code: xxxx xxxx xxxx xxxx xxxx xxxx xxxx xxxx
Please help.
Edited by
Discussion_Admin
philip.s
Hi Scott!
As you can see your reply was edited by our moderator / please refrain from posting sensitive information as this is a public forum.
The serial number that you provided (ending in 5473) is not in our system nor does it have the numbering structure typically seen in one of our valid licenses. With that being said, can you verify that this was purchased through an Autodesk Authorized Reseller?
If so, can you please send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with the relevant order information.
If not, I'd strongly suggest contacting the seller and requesting a refund.
Please let me know if you have any additional questions!
Administrator Productivity
