Installation & Licensing
"microsoft visual c++ redistributable" disk requested
7 REPLIES 7
Message 1 of 8
1564 Views, 7 Replies
I had the English version of Revit 2012 and now I uninstalledi it in order to reinstall the Italian one as I was told by Autodesk.
Now I can't do it because, before the beginning of the installation process, the "microsoft visual c++ redistributable x86 9.0.30729.4148" external disk is requested.
I have it already installed but I can't fix the problem.
I have Win Vista Home premium,
Thanx!
Manuela
7 REPLIES 7
Message 2 of 8
Dwayne.Poot
Hi Archimeg3
   It sounds like the installation has become corrupt. Have you tried to remove the C++ installation and try to re-install from the Microsoft site?
http://www.microsoft.com/download/en/details.aspx?id=5555
Dwayne
Dwayne Poot
Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 8
in reply to: Dwayne.Poot
Thank you Dwayne, I have just tried to uninstall it (I had so many versions of C++ installed, I had to clean a lot ;-)) ant to reinstall it from the link you sent but no way...
It still says that an external source (DVD, usb...) is needed to install Microsoft Visual C++ 2008 Redistributable (x86).
Maybe I reinstalled a wrong version?
Ciao,
Manuela
Message 4 of 8
TravisNave
Message 5 of 8
in reply to: TravisNave
Just tried, no way again.
It says that file vc_red.msi must have been moved in a different folder.
Maybe I have to download http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=6922 ?
Message 6 of 8
TravisNave
Nope, that doesn't look right. You need Visual C++ 2008 Redistributable x86.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 7 of 8
hashim.mundol
Have you managed to clean the VC++ installations ?
if not please use the clean up tool from MS
http://support.microsoft.com/mats/Program_Install_and_Uninstall
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 8 of 8
hashim.mundol
Have you managed to fix this issue ?
Hashim Mundol
Autodesk, Inc.
Administrator Productivity
