Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
Did you mean:Ā
"autodesk revit has stopped working"
4 REPLIES 4
Refiller
1390 Views, 4 Replies
i had just install autodesk revit 2014 student version. after instaling it, i had double click on the "revit" to open to program and three different tab pop up.
1 ) autodesk revit has stopped working
2 ) autodesk component has stopped working
3) autodesk licencing
anyone have any idea of fixing this?
please see below as a picture format
Thanks!
4 REPLIES 4
pendean
in reply to: Refiller
What is your OS and PC specs?
Refiller
in reply to: pendean
window 7
Processor : Intel core i7 CPU @ 2.20 GHz
Memory (RAM) : 6.00 GB
System type : 64-bit operating system
emily.xu
Hi
Welcome to Autodesk discussion group!
Please check if you're using IE10, if yes, try to uninstall 10 and back to IE8 or 9, see if works for you.
Emily Xu
Product Support
Refiller
in reply to: emily.xu
i had IE10, after unintalling it and turn it into IE9 it now works!
thanks a bunch!
Administrator Productivity
