• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    philip.s
    Re: "Setup initialization failed"-message pop up when I try to install
    09-21-2012 12:03 PM in reply to: amandaer
    You're best bet amandaer might just be to download the software onto another computer and then transfer the contents over to yours for the install.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Please use plain text.
    Active Member
    09-21-2012 12:07 PM in reply to: philip.s
    I have tried that, then I get the error "The installation package was moved from the install location, which is not supported".
    philip.s
    09-21-2012 12:13 PM in reply to: amandaer
    It's all dependent on the download method / that looks like it would have resulted from Install Now. If you choose the Browser Download option, you would just be moving an .exe file from one machine to another which doesn't require additional communication with the initial machine.
    Philip Schmelzer
    TW | PI | YT | BLOG
    Active Member
    09-21-2012 12:22 PM in reply to: philip.s
    The time I got the file from a friend was a couple of weeks ago when I first encountered the problem, I do not remember the download method. It was not that image posted that occurred then, I did not take a screen shot of it.. The image I posted was when trying to open the Install now I did an hour ago.
    I will try to get help from a friend and fetch the "browser download file" from him/her. I'll let you know when I (hopefully) have solved it.
    Thanks!
    Active Member
    09-29-2012 10:35 PM in reply to: amandaer
    Finally got it working: I had to browser download in mozilla-browser (did not work with any ither) while having my firewall off, and installing it and register it manually.
    Thanks alot guys!
    //Amanda
    New Member
    10-02-2012 09:17 PM in reply to: philip.s
    @Amander,
    Can u list out that how you solve the problem?
    I also faced this problem, please.
    Please list out step by step....
    philip.s
    10-03-2012 09:48 AM in reply to: nataline_wen89
    Hi Yan,
    From the previous post, it looks like Amanda switched browsers (Firefox), disabled the firewall, used the browser download option, and registered manually here.
    Philip Schmelzer
    TW | PI | YT | BLOG
    Active Member
    10-03-2012 10:47 AM in reply to: philip.s
    .. what he said.. =)
