Installation & Licensing
philip.s
Message 11 of 25 (3,159 Views)
Re: "Setup initialization failed"-message pop up when I try to install
09-21-2012 12:03 PM in reply to: amandaer
You're best bet amandaer might just be to download the software onto another computer and then transfer the contents over to yours for the install.
Philip Schmelzer
Active Member
Message 12 of 25 (3,157 Views)
09-21-2012 12:07 PM in reply to: philip.s
I have tried that, then I get the error "The installation package was moved from the install location, which is not supported".
philip.s
Message 13 of 25 (3,151 Views)
09-21-2012 12:13 PM in reply to: amandaer
It's all dependent on the download method / that looks like it would have resulted from Install Now. If you choose the Browser Download option, you would just be moving an .exe file from one machine to another which doesn't require additional communication with the initial machine.
Philip Schmelzer
Active Member
Message 14 of 25 (3,148 Views)
09-21-2012 12:22 PM in reply to: philip.s
The time I got the file from a friend was a couple of weeks ago when I first encountered the problem, I do not remember the download method. It was not that image posted that occurred then, I did not take a screen shot of it.. The image I posted was when trying to open the Install now I did an hour ago.
I will try to get help from a friend and fetch the "browser download file" from him/her. I'll let you know when I (hopefully) have solved it.
Thanks!
Active Member
Message 15 of 25 (3,099 Views)
09-29-2012 10:35 PM in reply to: amandaer
Finally got it working: I had to browser download in mozilla-browser (did not work with any ither) while having my firewall off, and installing it and register it manually.
Thanks alot guys!
//Amanda
New Member
Message 16 of 25 (3,065 Views)
10-02-2012 09:17 PM in reply to: philip.s
@Amander,
Can u list out that how you solve the problem?
I also faced this problem, please.
Please list out step by step....
philip.s
Message 17 of 25 (3,041 Views)
10-03-2012 09:48 AM in reply to: nataline_wen89
Hi Yan,
From the previous post, it looks like Amanda switched browsers (Firefox), disabled the firewall, used the browser download option, and registered manually here.
Philip Schmelzer
Active Member
Message 18 of 25 (3,035 Views)
10-03-2012 10:47 AM in reply to: philip.s
.. what he said.. =)
Member
Message 19 of 25 (2,055 Views)
06-20-2013 05:13 PM in reply to: david.lau
Hi
I have serious problem here. I cant download CIvil 3D trial. I have tried on multiple PC and it said "Connection has expired. Reconnect the site" I have restart and clear my browsing data and it still the same. Any help would be appriciated. Thx
philip.s
Message 20 of 25 (2,032 Views)
06-21-2013 09:22 AM in reply to: Rijal29
Hello Muhammad.
As a workaround, can you please access the trial software through Matt, our Virtual Assistant, and let us know if that resolves the issue?
From Matt: Download and Installation -> Software Download Links -> I need to redownload my product
Philip Schmelzer
You are not logged in.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
