• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    "Setup initialization failed"-message pop up when I try to install any product!
    2660 Views, 17 Replies
    09-18-2012 08:04 PM
    I have a new Windows 7 64bit laptop which I am trying to get the student license for AutoCAD, Revit and 3dsMax installed on. I have been trying for weeks, but after downloading the installation file and pushing the install button I constantly get the error: "Setup initialization failed. Connection has expired. Please reconnect to site."
    It seems like Autodesk can't recognize that I am in fact logged on, and I have been trying to log off- log on to try to solve it but I keep on getting the same error.
    The internet is not the problem, my friend managed to install AutoCAD on his computer on the same line.
    Please help, what can I do?
    Grateful for any advice,
    Amanda
    Please use plain text.
    Product Support
    Re: "Setup initialization failed"-message pop up when I try to install
    09-20-2012 06:37 AM in reply to: amandaer
    Are you able to download the software as a 'browser" download?
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    Active Member
    09-20-2012 08:19 AM in reply to: amandaer
    Yup I can download it, but when pressing install I get the error code.. I wanted to try it again now, but there seems so be a problem with me signing in at http://students.autodesk.com/?nd=login, I only get an error code when trying to log on. Logging on here was not a problem though.. Strange!
    Thanks!
    philip.s
    09-20-2012 09:09 AM in reply to: amandaer
    Hi amandaer
    I just reset your Education Community password (of which I'll be sending you the details via email) and verified access. Please delete your temporary internet files, clear the cache etc. and try logging in again. If you're still receiving the error you may want to consider switching browsers.
    Please let us know if the browser download option resolves your issue.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Active Member
    09-21-2012 11:10 AM in reply to: amandaer
    Tried to install Revit by browser downloading, but half way through the process I got this error instead: See attached image.
    Something definitively strange is going on.
    Amanda
    Active Member
    09-21-2012 11:13 AM in reply to: amandaer
    The same thing happened to me trying to install 3dsMAX, see image.
    philip.s
    09-21-2012 11:22 AM in reply to: amandaer
    Hi amandaer,
    CRC errors may be avoided by using a different web browser, an alternate download method (maybe try the Download Now option), or by temporarily disabling all anti virus software and firewalls as they may be prematurely ending the download.
    Philip Schmelzer
    TW | PI | YT | BLOG
    Active Member
    09-21-2012 11:38 AM in reply to: philip.s
    Thanks Philip,
    Ok, so now I have tried changing to the Mozilla browser and tried to "install now” that resulted in the same primary error popping up.. Then I also tried doing it while my firewall and virus program was totally switched of, that did not work either. Then I tried installing the browser downloaded over night with the protection switched of, but the same problems I got recently occurred. Nothing is working..
    philip.s
    09-21-2012 11:42 AM in reply to: amandaer
    You're welcome amandaerDid you try the Download Now option?
    Philip Schmelzer
    TW | PI | YT | BLOG
    Active Member
    09-21-2012 11:50 AM in reply to: philip.s
    Yup, both with and without the computer protection on.. I get the same error as I did the first times. See image
