Installation & Licensing
Valued Contributor
pete592
Message 1 of 47 (14,576 Views)
"First Run Initialization" Every Time I Start AutoCAD 2012 Mechanical
14576 Views, 46 Replies
04-21-2011 09:01 AM
Each morning when I start AutoCAD 2012 Mechanical, The startup banner comes up and does the "First Run Initialization" and its subsequent, lengthy loading and install process of every nut and bolt of the software.
I am running Vista, while the other two users in my office are still on XP (don't ask me why) and they are not experiencing this.  Theirs are much faster and more typical of a routine startup.
If there is any system information that may be helpful, please don't hesitate to ask.  I have no clue where to begin.
Pete
Member
marcouellette2371
Message 2 of 47 (14,479 Views)
Re: "First Run Initialization" Every Time I Start AutoCAD 2012 Mechan
05-02-2011 09:11 AM in reply to: pete592
Sorry I can't assist because I am also having the same issue, except that my OS is Windows 7.
*Expert Elite*
TravisNave
Message 3 of 47 (14,458 Views)
05-02-2011 02:35 PM in reply to: pete592
Two things to check for would be:
1.  Make sure you have Local Administrative privileges on your machine.
2.  Make sure you aren't using Roaming Profiles where your Windows Profile exists on a server.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
bartdoedens
Message 4 of 47 (14,447 Views)
05-02-2011 05:48 PM in reply to: TravisNave
Hi guys, I had the same issue on my computer which has Windows 7 Pro 64bit. I logged off my profile and login as the Administrator then ran AutoCAD and once again it went through the First Run Initialization as it was doing under my profile. When I ran AutoCAD again after that it started without doing the First Run Initialization. For some reason AutoCAD was having problem writing the First Run Initialization to the registry under my profile even though I was a local administrator.
Hope that helps guys.
New Member
s2ghaziz
Message 5 of 47 (14,407 Views)
05-05-2011 07:51 AM in reply to: pete592
I'm experiencing the same issue running AutoCAD 2012 - Student Version. I have a windows 7 64bit laptop. Is there any way to fix this?
*Expert Elite*
TravisNave
Message 6 of 47 (14,402 Views)
05-05-2011 11:06 AM in reply to: s2ghaziz
Run as Administrator or make sure you have admin rights on your system.  If not, recreate your Windows profile.
Member
sergio.kraljicjr
Message 7 of 47 (14,219 Views)
05-25-2011 10:25 AM in reply to: pete592
I have this issue even though I have full administrative rights under my User Profile (XP Professional). Once the first run initializing is complete subsequent startups of the software load normally. However, when the computer is rebooted (not just logged off) and I log in again, the first run initializing reappears. This has not happened with Autocad 2011...hopefully Autodesk support will address this.
kmiller
Message 8 of 47 (14,153 Views)
05-31-2011 12:58 PM in reply to: sergio.kraljicjr
Same issues here - Windows XP, sp2 64-bit. - I am not running mechanical, just plain ACAD.  I also have admin rights to my computer.
If this response answers your question please click "Accept as Solution".
Member
u4301887
Message 9 of 47 (13,540 Views)
08-22-2011 05:32 PM in reply to: kmiller
Here's my solution (I'm running WIn7 x64 Pro):
If you have it pinned to the taskbar:
1. Right-click on the icon, then right click on 'AutoCAD 2012' (or whatever version you have) and select 'Properties':
Step 1
2. On the 'Shortcut' tab, click the 'Advanced...' button:
3. Tick the 'Run as administrator' box, and all the 'OK's, and you're done.
Active Contributor
rms390
Message 10 of 47 (13,296 Views)
09-08-2011 05:47 AM in reply to: u4301887
same problem... windows xp sp3... admin and all that... it remembers the initialization until the computer gets turned off
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
