Installation & Licensing
New Member
Message 21 of 45 (7,680 Views)
Re: "First Run Initialization" Every Time I Start AutoCAD 2012 Mechan
05-01-2012 11:43 AM in reply to: pete592
We are having a problem that seems very similar to this as well.
As an administrator typically we can run ACAD here at our office, however it is completely ridiculous to require users that have no business being admins, to be admins to run the program.
If we use a profile for ACAD the problem seems much worse.
Also, to run ACAD, a user can not simply be a local admin (which is BAD enough to require), they must be AT LEAST a Domain Admin. This a completely unacceptable. we need normal, NON-ADMINS, to be able to use ACAD. Having normal users as Admins is a HUGE security risk, and not only can but will cause network problems from users doing things they should not be doing.
Please help ACAD (or anyone else), this is a REALLY BIG problem.
Active Contributor
rms390
Message 22 of 45 (7,669 Views)
05-02-2012 03:57 AM in reply to: adillberg
lol they have known about this for a year now.... They don't fix the issue and im pretty sure 2013 has the same problem.  I downloaded the student version on my home pc to try it out and boom, first run initialization every fresh start of autoCAD
david.scheu
Message 23 of 45 (7,659 Views)
05-02-2012 07:37 AM in reply to: adillberg
Adillberg, I think it's pretty clear at this point that having administrator rights does not necessarily make this problem go away (doesn't for me; hasn't for several other posters). Are you saying that it does for you?
User rights could be part of the problem, but for various reasons I don't think they are. (And if they are, it ought to be enough to run once as admin, and subsequently as a standard user.)
It would be helpful to know if anyone out there is running AutoCAD without administrator priveleges and not experiencing this problem. It would also be helpful to hear from anyone who has actually had the problem and then made it go away by elevating user rights. If so, does it come back if you switch back to standard user rights?
New Member
Message 24 of 45 (7,513 Views)
06-04-2012 10:46 AM in reply to: pete592
can't make what you recomend.... the option is grayed out... ¿any idea? (with other software, I actually can)
New Member
Message 25 of 45 (7,201 Views)
08-04-2012 12:29 PM in reply to: jhudtwalcker
This is the issue ever since version 2012. In 2013, I'm also having the same problem. I hit the activation limit, because every time AutoCAD starts it requests a key. I've already 5 e-mails with keys I requested from A SINGLE, FRESH INSTALLATION OF AUTOCAD 2013 (I'm a student - I'd like to at least have one license valid on a laptop and another on my home box, in order to work comfortably wherever I am. That's already impossible). That's five activations of autocad 2013 over a timespan of 4 days - every day I came to work, plus today.
I had to stop using AutoCAD overall due to this fault, because version 2012 was rendered completely useless after installing it, uninstalling and installing again (apparently, installing and uninstalling software destroys the license manager). I've even made a completely fresh windows 7 x64 installation (the one I'm using right now) in order to install ACAD2012. Installed, problem persists. Good thing that inventor is still working, hope they won't switch to the same licensing scheme.
If anyone requests further information / screenshots, please let me know, I'll upload it on demand.
Message 26 of 45 (7,049 Views)
08-21-2012 07:16 AM in reply to: adillberg
Has anyone found a fix for this issue? I am an admin over my computer, my IT Tech assures me, we do not have roaming profiles, and I have the Run As Administrator checked. Nothing has fixed the issue.
We have 3 identicle, user dedicated computers in our dept and they all do it.
Can someone point me in the right direction if there is a fix. I can't seem to find anything.
Windows 7 64-bit
We have APDS Ultimate 2012
New Member
Message 27 of 45 (6,689 Views)
10-01-2012 06:57 AM in reply to: cmiller
Delete the original shortcut on the desktop.
Copy and paste the shortcut added in the start menu, autodesk....on your desktop or create a new one pointing to acad.exe
And voila....
david.scheu
Message 28 of 45 (6,681 Views)
10-01-2012 08:30 AM in reply to: dperret
That didn't work for me. Tried copying (they were identical but tried anyway) and tried creating a new link. Same result each time.
Message 29 of 45 (6,679 Views)
10-01-2012 08:34 AM in reply to: david.scheu
Didn't work for me either.:smileyindifferent:
Active Contributor
Message 30 of 45 (5,278 Views)
02-21-2013 01:32 PM in reply to: adillberg
Hey All. Late to the party but I found one possible legit fix for this issue (at least in regards to 2013 AutoCAD Raster on Windows 7).
My company has every version of CAD under the sun, and when installing AutoCAD and initialing it, I chose AutoCAD Raster for Structural rather than vanilla AutoCAD Raster 2013.  I didn’t think much of it until it kept initializing.
So I went into the Registry and looked for anything anomalous between 2012 which was working and 2013 which was not. I found that a Registry key under:
Current User -> Software -> AutoDesk -> AutoCAD -> R19.0 -> AutoCAD Raster 2013
did not match
Current User -> Software -> AutoDesk -> AutoCAD -> R18.2 -> AutoCAD Raster 2012
The key should be" C:\Users\**insert user here***\AppData\Local\Autodesk\AutoCAD 2013 - English\R19.0\enu\"
but instead pointed to a folder in the Appdata that didn’t exist.
Same also had to be done for the other key showing the Roaming Folder location.
I believe that without those keys pointing to legit folders, AutoCAD assumes its not installed and trys to initalize it again upon the next load.
Hopefully this can be extrapolated (or at least serving as a starting point) for others.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
