Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
"First Run Initializa tion" Every Time I Start AutoCAD 2012 Mechanical
- Highlight
- Email to a Friend
Each morning when I start AutoCAD 2012 Mechanical, The startup banner comes up and does the "First Run Initialization" and its subsequent, lengthy loading and install process of every nut and bolt of the software.
I am running Vista, while the other two users in my office are still on XP (don't ask me why) and they are not experiencing this. Theirs are much faster and more typical of a routine startup.
If there is any system information that may be helpful, please don't hesitate to ask. I have no clue where to begin.
Pete
Re: "First Run Initializa tion" Every Time I Start AutoCAD 2012 Mechan
- Highlight
- Email to a Friend
Sorry I can't assist because I am also having the same issue, except that my OS is Windows 7.
- Highlight
- Email to a Friend
Two things to check for would be:
1. Make sure you have Local Administrative privileges on your machine.
2. Make sure you aren't using Roaming Profiles where your Windows Profile exists on a server.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: "First Run Initializa tion" Every Time I Start AutoCAD 2012 Mechan
- Highlight
- Email to a Friend
Hi guys, I had the same issue on my computer which has Windows 7 Pro 64bit. I logged off my profile and login as the Administrator then ran AutoCAD and once again it went through the First Run Initialization as it was doing under my profile. When I ran AutoCAD again after that it started without doing the First Run Initialization. For some reason AutoCAD was having problem writing the First Run Initialization to the registry under my profile even though I was a local administrator.
Hope that helps guys.
- Highlight
- Email to a Friend
I'm experiencing the same issue running AutoCAD 2012 - Student Version. I have a windows 7 64bit laptop. Is there any way to fix this?
- Highlight
- Email to a Friend
Run as Administrator or make sure you have admin rights on your system. If not, recreate your Windows profile.
- Highlight
- Email to a Friend
I have this issue even though I have full administrative rights under my User Profile (XP Professional). Once the first run initializing is complete subsequent startups of the software load normally. However, when the computer is rebooted (not just logged off) and I log in again, the first run initializing reappears. This has not happened with Autocad 2011...hopefully Autodesk support will address this.
- Highlight
- Email to a Friend
Same issues here - Windows XP, sp2 64-bit. - I am not running mechanical, just plain ACAD. I also have admin rights to my computer.
If this response answers your question please click "Accept as Solution".
- Highlight
- Email to a Friend
Here's my solution (I'm running WIn7 x64 Pro):
If you have it pinned to the taskbar:
1. Right-click on the icon, then right click on 'AutoCAD 2012' (or whatever version you have) and select 'Properties':
2. On the 'Shortcut' tab, click the 'Advanced...' button:
3. Tick the 'Run as administrator' box, and all the 'OK's, and you're done.
- Highlight
- Email to a Friend
same problem... windows xp sp3... admin and all that... it remembers the initialization until the computer gets turned off
