Installation & Licensing
Member
Compgeke
Message 1 of 6 (1,225 Views)
"Autodesk Download Manager has stopped working" - Autodesk Inventor 2014 Pro
1225 Views, 5 Replies
04-25-2013 12:13 AM
I seem to be having a bit of a problem trying to get Autodesk Inventor 2014 to install. I downloaded the two .exe files rather than the web download manager, however when trying to run either one it asks where to extract to, and after hitting ok (doesn't matter what location you try) it crashes and I get the Windows 7 Autodesk Download Manager has stopped working error. The exception code is c0000094, which seems to be "Divide by Zero."
From the VS '12 Debugger (pretty basic):
Unhandled exception at 0x01252FD4 in Autodesk_Inventor_2014_Eng_64bit_dlm_001_002.sfx.exe: 0xC0000094: Integer division by zero.
It's not a disk space issue as far as I know, the drive I'm using has 862 gigs free space, which I can hope is more than enough (if you guys can pack a terabyte of data into a 4 gig file, you have some great compression).
Here's a screen shot of the error:
AutodeskCrashDLM
Valued Mentor
stephengibson76
Message 2 of 6 (1,204 Views)
Re: "Autodesk Download Manager has stopped working" - Autodesk Invento
04-25-2013 03:12 AM in reply to: Compgeke
same problem :smileysad:
Stephen Gibson
View stephen gibson's profile on LinkedIn
Member
Compgeke
Message 3 of 6 (1,191 Views)
04-25-2013 06:59 AM in reply to: stephengibson76
Just curious, are you running Windows 7 SP0 or SP1? I'm running SP0, and while I'm not sure if that's the problem, if you have SP1 it isn't.
marius
Message 4 of 6 (1,170 Views)
04-26-2013 12:26 PM in reply to: Compgeke
After dowloading almost 90% out of 31.9 GB, twice.
Member
Compgeke
Message 5 of 6 (1,136 Views)
04-28-2013 11:47 PM in reply to: Compgeke
I seem to have solved my own issue. It seems the drive I have the files stored on had a partially corrupt file system (FAT32) and after converting to NTFS I seem to be able to run the file with no problems.
Anyone who has a simiar problem when using browser download, try running chkdsk on your drive, see if that fixes the problem.
New Member
alaabarazi
Message 6 of 6 (436 Views)
03-04-2014 01:00 PM in reply to: Compgeke
The short answer is "Move your files to a drive which fromatted using NTFS file system".
For a reason exFat is causing this kind of error. I tried two exFat hardisks and USBs and got the same error.
When I moved the same files to exFat it worked.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
