Installation & Licensing
"AutoCAD 2004 License Alert" error message
1 REPLY 1
blittell
886 Views, 1 Reply
I upgraded the current FlexLM to version 8.3.1 per the instructions in "AutoCAD 2004 Network License Manager Quick Start Guide"; users can still run AutoCAD 2002.
When I installed AutoCAD 2004 on a workstation and tried to run it, I got the error message, "A valid license could not be obtained by the network license manager...".
The "FlexLM Service 1" is running without problems.
Is the problem that I need to get a new license file for the 2004 version? And if so, would a new license file prevent the 2002 version from running?
1 REPLY 1
in reply to: blittell
AutoCAD 2004 requires a new license file.  In
order to run multiple products the license files must be combined.  See
href="http://support.autodesk.com/getDoc.asp?id=TS65928">http://support.autodesk.com/getDoc.asp?id=...
If you upgraded your AutoCAD 2002 licenses to AutoCAD 2004 you no longer own
AutoCAD 2002 and you should not combine the license files.
Jerry Milana,
Autodesk Professional
Services
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
2002.
running?
Administrator Productivity
