Installation & Licensing
New Member
akpoveta
Message 1 of 3 (2,013 Views)
"AUTOCAD 2000i "FATAL ERROR : UNHANDLED e06d7363h EXCEPTION AT 77F1
2013 Views, 2 Replies
06-25-2001 08:30 PM
Within the last couple of days on lauching autocad 2000i, i am receiving an error message "FATAL ERROR : UNHANDLED e06d7363h EXCEPTION AT 77F1D493h" i have been to the knowledge base and the solution there requires me to be in autocad to implement the solution. But there is a problem as i can't lauch autocad.
any solution would be welcome, as i have tried all possible solution which include uninstalling the software and installing the software with out any luck.
Thanks.
Martin
Email add: martin@aaschool.ac.uk
*Madhanagopal
Message 2 of 3 (2,013 Views)
Re: "AUTOCAD 2000i "FATAL ERROR : UNHANDLED e06d7363h EXCEPTION AT
06-25-2001 09:17 PM in reply to: akpoveta
1. Uninstall AutoCAD 2000i using Add/Remove Programs from Windows Control
Panel.
2. Delete all files in C:\Program Files\Common Files\Autodesk Shared
directory.
Note: The Autodesk Shared file directory is always be placed
on the C:\
drive regardless of where AutoCAD 2000 is installed.
3. Reboot
the workstation.
4. Install AutoCAD 2000i.
Madhanagopal
AutoCAD & MCAD Product Support, INDIA
WW Support
& Services, Autodesk
Discussion Q&A:
href="http://www.autodesk.com/discussion">http://www.autodesk.com/discussion
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Within
luck.
Thanks.
Martin
New Member
akpoveta
Message 3 of 3 (2,013 Views)
Re:
06-25-2001 09:43 PM in reply to: akpoveta
AutoCad is installed via a network using a network licence. I have installed the autocad software on new Pc which hadn't autocad installed on it previously and the problem still occurs. i have a feeling that the error is occuring from the main server running the autocad licences.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
