Installation & Licensing
"AUTOCAD 2000i "FATAL ERROR : UNHANDLED e06d7363h EXCEPTION AT 77F1
2 REPLIES 2
akpoveta
4420 Views, 2 Replies
Within the last couple of days on lauching autocad 2000i, i am receiving an error message "FATAL ERROR : UNHANDLED e06d7363h EXCEPTION AT 77F1D493h" i have been to the knowledge base and the solution there requires me to be in autocad to implement the solution. But there is a problem as i can't lauch autocad.
any solution would be welcome, as i have tried all possible solution which include uninstalling the software and installing the software with out any luck.
Thanks.
Martin
Email add: martin@aaschool.ac.uk
2 REPLIES 2
in reply to: akpoveta
1. Uninstall AutoCAD 2000i using Add/Remove Programs from Windows Control
Panel.
2. Delete all files in C:\Program Files\Common Files\Autodesk Shared
directory.
Note: The Autodesk Shared file directory is always be placed
on the C:\
drive regardless of where AutoCAD 2000 is installed.
3. Reboot
the workstation.
4. Install AutoCAD 2000i.
Madhanagopal
AutoCAD & MCAD Product Support, INDIA
WW Support
& Services, Autodesk
Discussion Q&A:
href="http://www.autodesk.com/discussion">http://www.autodesk.com/discussion
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Within
luck.
Thanks.
Martin
akpoveta
AutoCad is installed via a network using a network licence. I have installed the autocad software on new Pc which hadn't autocad installed on it previously and the problem still occurs. i have a feeling that the error is occuring from the main server running the autocad licences.
Administrator Productivity
