Installation & Licensing
237 Views, 2 Replies
product updates
Product updates tells me my system is up to date. Where can I see what has been actually installed on my machine.
On the same note. When can I expect to see a patch for the UNDO problem as well as the Pressure Pipe multitudes of problems?
2 REPLIES 2
TravisNave
Help > About will show you the product version.  Add/Remove Programs in Control Panel will show your service updates.
Autodesk Forums:
david.lau
in reply to: TravisNave
What product is this for?  i.e. UNDO problem.
David Lau
Administrator Productivity
