Autocad used to work perfectly
now it wont launch
get this
Problem Event Name: APPCRASH
Application Name: acad.exe
Application Version: 23.0.54.0
Application Timestamp: 440acd95
Fault Module Name: StackHash_b07c
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c000041d
Exception Offset: 76dc1221
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 7177
Additional Information 1: b07c
Additional Information 2: b07c9f334ed23629f31261200e2152db
Additional Information 3: c5e2
Additional Information 4: c5e2938eff61fd2d71b1da696b2907b3
any ideas
What changed? That is what you will have to find the answer to. If it worked and now it doesn't, you need to find out why.
1. Windows updates?
2. Video Drive update?
3. Virus or spyware?
4. Updated the Autodesk software with a SP or hotfix?
5. Installed additional software that may have modified .NET or C++?
Something changed...
If you can pinpoint a location when you remember it working, you can try a system restore back to that date and see if the problem is fixed.
Good Luck!
Dont have a restore point far back enough---have been trying to uninstall and then reinstall.
Still get this
Locale ID: 7177
Is it an activation crash?
