after downloading the autodesk maya 2015, immediately i try to install it, a message read, procedure entry point could not be located in the dynamic link library. please someone help me with these
Hi @Anonymous,
Welcome to the Community. Try out the solution provided in this other post below which had the similar error you are having.
Revit.exe - Entry Point Not Found
Let us know how it goes. Thanks,
thanks for reply @jeffery. i tried the first two options and it didnt work, the last one may have worked if i had installed autodesk revit or maya before, but i hav not, only autodesk 3ds max 2013, maya2015 if the first version of maya am installing. so if there are other options pls let me know. thanks
