• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    deeon
    problem installing autodesk revit architecture
    160 Views, 2 Replies
    02-07-2012 01:54 AM
    Hi
    I've got a problem with installing autodesk revit architecture. When I'm trying to install the program I just get the message installation failed and i get this message on the installation log:
    deeon DEEON-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\deeon\AppData\Local\Temp\vcredist_x86_2010.log
    2012/2/6:19:14:45 deeon DEEON-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
    2012/2/6:19:14:45 deeon DEEON-PC PageOpen InstallCompleteDialog
    2012/2/6:19:14:52 deeon DEEON-PC === Setup ended ===
    2012/2/6:22:53:46 deeon DEEON-PC === Setup started on DEEON-PC by deeon ===
    2012/2/6:22:53:46 deeon DEEON-PC Launch
    2012/2/6:22:54:41 deeon DEEON-PC === Setup ended ===
    2012/2/6:22:53:48 deeon DEEON-PC === Setup started on DEEON-PC by deeon ===
    2012/2/6:22:53:48 deeon DEEON-PC Launch
    2012/2/6:22:54:41 deeon DEEON-PC PageOpen LaunchDialog
    2012/2/6:22:55:12 deeon DEEON-PC PageOpen LicenseDialog
    2012/2/6:22:55:16 deeon DEEON-PC PageOpen ProductInfoDialog
    2012/2/6:22:55:34 deeon DEEON-PC PageOpen ProductSelectionDialog2
    2012/2/6:22:55:50 deeon DEEON-PC PageOpen FullProgressDialog
    2012/2/6:22:55:51 deeon DEEON-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\deeon\AppData\Local\Temp\vcredist_x86_2010.log
    2012/2/6:22:55:52 deeon DEEON-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
    2012/2/7:10:24:34 deeon DEEON-PC === Setup started on DEEON-PC by deeon ===
    2012/2/7:10:24:34 deeon DEEON-PC Launch
    2012/2/7:10:25:23 deeon DEEON-PC === Setup ended ===
    2012/2/7:10:24:35 deeon DEEON-PC === Setup started on DEEON-PC by deeon ===
    2012/2/7:10:24:35 deeon DEEON-PC Launch
    2012/2/7:10:25:23 deeon DEEON-PC PageOpen LaunchDialog
    2012/2/7:10:27:20 deeon DEEON-PC PageOpen LicenseDialog
    2012/2/7:10:27:34 deeon DEEON-PC PageOpen ProductInfoDialog
    2012/2/7:10:27:51 deeon DEEON-PC PageOpen ProductSelectionDialog2
    2012/2/7:10:28:02 deeon DEEON-PC PageOpen FullProgressDialog
    2012/2/7:10:28:02 deeon DEEON-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\deeon\AppData\Local\Temp\vcredist_x86_2010.log
    2012/2/7:10:28:04 deeon DEEON-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
    what do i have to do to fix this?
    I have windows 7 on my computer
    ***Guru
    TravisNave
    Re: problem installing autodesk revit architecture
    02-07-2012 08:39 AM in reply to: deeon
    Go into your Control Panel > Programs and uninstall your Visual C++ 2010.  Then reinstall your Autodesk software.
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    deeon
    02-07-2012 12:07 PM in reply to: TravisNave
    thank you It worked :smileyhappy:
