• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Active Member
    b-chill
    problem installing Autocad 2012
    1650 Views, 9 Replies
    01-10-2012 12:18 PM
    Hello there...
    For months , i have tried to install autocad on my thinkpad t420.
    But now i have given up. I have the same problem as so many else in here: During installation computer restarts. And it has something to do with the .net framework.
    I tried all the sollutions posted in previous post, so what to do now ?
    Attachted is the installation log file...
    regards
    Jesper
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: problem installing Autocad 2012
    01-10-2012 02:32 PM in reply to: b-chill
    Remove all instances of your .NET Framework and let Autodesk reinstall the version it wants.
    .NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
    http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
    Good Luck!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    b-chill
    01-12-2012 11:56 AM in reply to: b-chill
    Well,
    Really hoped this would solve the issue, but im afraid it didnt.
    The tool worked without any issues, but still install fails upon finishing the net framework install.
    log file attachted
    *Expert Elite*
    TravisNave
    01-12-2012 12:02 PM in reply to: b-chill
    Sounds like you have a pretty fun problem there with your .NET Framework.  Go to Microsoft.com and install the latest 4.0.  Make sure it installs without error.
    Then copy your 2012 media to your hard drive.  Edit the setup.ini file to exclude the DOTNETFX prerequisites and subsequent sections underneath.  That will prevent the installer from even checking or installing .NET from supplied media.  The rest of your install should go without a hitch.  Good Luck!
    Travis Nave
    Active Member
    b-chill
    01-13-2012 02:38 AM in reply to: b-chill
    hmm.. things only got even worse now. Setup ends even faster.
    maybe i didnt edit the ini file correctly?
    attached is original and edited ini plus the new log file
    *Expert Elite*
    TravisNave
    01-13-2012 07:54 AM in reply to: b-chill
    You did a pretty good job but you forgot to actually remove the prerequisite installer sections below it.  Here is my edited version.  Try it and see if it works for you.  Just remove the .txt, of course.
    Travis Nave
    *Expert Elite*
    TravisNave
    01-13-2012 08:51 AM in reply to: b-chill
    I checked your install log and now it seems to be failing on Visual C++ 2008.  If you have a newer version installed already, uninstall it from Control Panel.  See then if you can install it manually from Microsoft here:
    http://www.microsoft.com/download/en/details.aspx?id=2092
    Then run your setup again and let me know.  We'll hopefully get this by hook or by crook.  :smileywink:
    Edit:  Adding the setup.ini file without the Visual C++ prereq check.  If the above doesn't work, try this file too.  Just make sure that all of your .NET and Visual C++ are actually installed or your product will not work.
    Travis Nave
    Active Member
    b-chill
    01-14-2012 03:25 AM in reply to: b-chill
    thank you by the way for being so helpful, of course it should be possible to install in some way. i will try your suggestens asap.
    do you by any chance think that my problems could have something to do with my lenovo-branded version of windows?
    *Expert Elite*
    TravisNave
    01-16-2012 08:30 AM in reply to: b-chill
    I doubt that.  As you can tell from the other posts in this forum, there are lots of reasons for installation errors.  It's just a matter of figuring out yours.  :-)
    Travis Nave
    Member
    11-25-2012 02:36 PM in reply to: TravisNave
    Hello TravisNave,
    I encounter the same error message 0x0000 to launch autocad 2013 ... I try to uninstall everything, to reinstall, uninstall of the framework, to reinstall, to understand all the actions you describe, but without success. So I came across this discussion intrigues me a lot, that's why I'm here. I think the problem is with windows 8 because it worked before on my windows 7, but I confess I do not understand how to modify the setup.ini file. If it can save my setup that would be great, otherwise I'll have to switch back to windows 7, it would be a shame:smileywink: If you have a solution to my problem, I would really appreciate you helping me.
    Sorry for my bad English surely, I used an automatic translator
    Sincerely,
    Ben
