Installation & Licensing
Member
y.m.b
Message 1 of 8 (925 Views)
problem installing AutoCAD 2012
925 Views, 7 Replies
09-05-2011 01:16 PM
Hey, I am having problem installing AutoCAD 2012. Almost when the installation process is done I keep receiving this message:
CRC failed in x64\acad\Program Files\Root\Inventor Server\Bin\ASMKERN217I.dll Unexpected end of archive
I already download .Net 4.0 and DirectX End User Runtimes (March 2009). I do not know what else to do. Can someone help me?
*Expert Elite*
Alfred.NESWADBA
Message 2 of 8 (924 Views)
Betreff: problem installing AutoCAD 2012
09-05-2011 01:25 PM in reply to: y.m.b
CRC-failure is a checksum-failure. When uncompressing a file or when downloading a file, the filesize will be checked against the checksum-value and that seems to have failed during your installation.
If you have downloaded the setup-dvd-content you should do a download once more. Autodesk recommends the use of their download-manager.
If you have started the installation from a dvd, try to copy the content of the dvd to a new directory on your local harddisk and start the setup.exe from this directory.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Member
y.m.b
Message 3 of 8 (919 Views)
09-05-2011 02:24 PM in reply to: Alfred.NESWADBA
how can I download the setup dvd content? I am downloading it from the autodeskk student community.
*Expert Elite*
pendean
Message 4 of 8 (914 Views)
Re: problem installing AutoCAD 2012
09-05-2011 04:55 PM in reply to: y.m.b
Redownload and make sure you use the download manager from the student site (sounds like you cancelled this option when you did it the last time)
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
y.m.b
Message 5 of 8 (899 Views)
09-05-2011 11:03 PM in reply to: pendean
i used the download manager from the website and I keep getting  the same message. I think I going to download the 2011 version instead. Thanks for your help.
*Expert Elite*
Alfred.NESWADBA
Message 6 of 8 (896 Views)
09-05-2011 11:58 PM in reply to: y.m.b
I would not run 2011 when I would have the chance to get 2012.  :smileywink:
Well, I had problems with downloading, I did it three times and all received files where defect, 2 days later I tried it once more (did the update parallel, one with download-manager, the other without) and then it worked.
For me it was interesting that I never had file-corruption during download and then 3 times and constant failed. :smileysad: However two days later it worked. Maybe you also try it also without downloadmanager, on another pc, ... In normal cases, the setup's donn't hace CRC-failures.
Goog luck, - alfred -
Alfred NESWADBA
*Expert Elite*
TravisNave
Message 7 of 8 (860 Views)
09-07-2011 10:04 AM in reply to: Alfred.NESWADBA
CRC and download manager issues may be resolved by using the alternate browser download method.  See the blog post here for more information:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
y.m.b
Message 8 of 8 (797 Views)
09-10-2011 10:44 PM in reply to: TravisNave
Thank you so much for your help. I was able to download autocad 2012 using firefox. I have no idea why but it work. thanks for everything
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
