the end of installation for both revit 2013 or 2014 on my windows 8 glitch interrupting the installation
Here in my Log error,
2014/2/5:15:28:30 Arianne ARIANNEFRATELLI === Setup started on ARIANNEFRATELLI by Arianne ===
2014/2/5:15:28:30 Arianne ARIANNEFRATELLI Path_Length: 149
2014/2/5:15:28:30 Arianne ARIANNEFRATELLI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/5:15:28:30 Arianne ARIANNEFRATELLI Launch
2014/2/5:15:28:30 Arianne ARIANNEFRATELLI CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-32234522 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/5:15:28:30 Arianne ARIANNEFRATELLI Current Directory C:\Users\Arianne\AppData\Local\Temp\_AI2B2.tmp
2014/2/5:15:29:36 Arianne ARIANNEFRATELLI === Setup ended ===
2014/2/5:15:28:33 Arianne ARIANNEFRATELLI === Setup started on ARIANNEFRATELLI by Arianne ===
2014/2/5:15:28:33 Arianne ARIANNEFRATELLI Path_Length: 149
2014/2/5:15:28:33 Arianne ARIANNEFRATELLI Current Directory C:\Users\Arianne\AppData\Local\Temp\_AI2B2.tmp
2014/2/5:15:28:33 Arianne ARIANNEFRATELLI Launch
2014/2/5:15:28:36 Arianne ARIANNEFRATELLI Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/5:15:29:35 Arianne ARIANNEFRATELLI Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/5:15:29:35 Arianne ARIANNEFRATELLI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Arianne\AppData\Local\Temp\_AI2B2.tmp\Setup\RevitSetup.dll
2014/2/5:15:29:35 Arianne ARIANNEFRATELLI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/5:15:29:36 Arianne ARIANNEFRATELLI PageOpen LaunchDialog
2014/2/5:15:36:46 Arianne ARIANNEFRATELLI PageOpen LicenseDialog
2014/2/5:15:38:42 Arianne ARIANNEFRATELLI PageOpen ProductInfoDialog
2014/2/5:15:38:42 Arianne ARIANNEFRATELLI PageOpen ProductSelectionDialog2
2014/2/5:15:38:53 Arianne ARIANNEFRATELLI PageOpen FullProgressDialog
2014/2/5:15:38:54 Arianne ARIANNEFRATELLI Download Play VCREDIST2008SP1X64_6161 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/5:15:39:00 Arianne ARIANNEFRATELLI Download Complete VCREDIST2008SP1X64_6161 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/5:15:39:00 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2014/2/5:15:39:39 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2014/2/5:15:39:39 Arianne ARIANNEFRATELLI Download Play VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/5:15:39:43 Arianne ARIANNEFRATELLI Download Complete VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/5:15:39:43 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Arianne\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/5:15:40:18 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/2/5:15:40:18 Arianne ARIANNEFRATELLI Download Play VCREDIST2008SP1X86_6161 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/5:15:40:24 Arianne ARIANNEFRATELLI Download Complete VCREDIST2008SP1X86_6161 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/5:15:40:24 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2014/2/5:15:41:04 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2014/2/5:15:41:04 Arianne ARIANNEFRATELLI Download Play KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:41:04 Arianne ARIANNEFRATELLI Download Complete KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:41:04 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/5:15:41:11 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/5:15:41:12 Arianne ARIANNEFRATELLI Download Play KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:41:20 Arianne ARIANNEFRATELLI Download Complete KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:41:20 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/5:15:41:35 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/5:15:41:36 Arianne ARIANNEFRATELLI Download Play KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:41:37 Arianne ARIANNEFRATELLI Download Complete KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:41:37 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/5:15:41:51 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/5:15:41:51 Arianne ARIANNEFRATELLI Download Play KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:41:52 Arianne ARIANNEFRATELLI Download Complete KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:41:52 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/5:15:42:05 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/5:15:42:06 Arianne ARIANNEFRATELLI Download Play KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:42:06 Arianne ARIANNEFRATELLI Download Complete KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:42:06 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/5:15:42:12 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/5:15:42:13 Arianne ARIANNEFRATELLI Download Play KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:42:21 Arianne ARIANNEFRATELLI Download Complete KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:42:21 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/5:15:42:37 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/5:15:42:37 Arianne ARIANNEFRATELLI Download Play KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:42:38 Arianne ARIANNEFRATELLI Download Complete KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:42:38 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/5:15:42:50 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/5:15:42:50 Arianne ARIANNEFRATELLI Download Play KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:42:50 Arianne ARIANNEFRATELLI Download Complete KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/5:15:42:50 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/5:15:43:03 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/5:15:43:03 Arianne ARIANNEFRATELLI Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/5:15:43:06 Arianne ARIANNEFRATELLI Download Complete VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/5:15:43:06 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Arianne\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/2/5:15:43:54 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/2/5:15:43:54 Arianne ARIANNEFRATELLI Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/5:15:43:57 Arianne ARIANNEFRATELLI Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/5:15:43:57 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Arianne\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/5:15:44:56 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/2/5:15:44:57 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2014/2/5:15:45:03 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/5:15:45:08 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/5:15:45:14 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/5:15:45:17 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/5:15:45:23 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/5:15:45:28 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/5:15:45:34 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/5:15:45:37 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/5:15:45:37 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/2/5:15:45:38 Arianne ARIANNEFRATELLI PageOpen InstallCompleteDialog
2014/2/5:15:46:35 Arianne ARIANNEFRATELLI === Setup ended ===
2014/2/10:21:52:50 Arianne ARIANNEFRATELLI === Setup started on ARIANNEFRATELLI by Arianne ===
2014/2/10:21:52:50 Arianne ARIANNEFRATELLI Path_Length: 149
2014/2/10:21:52:50 Arianne ARIANNEFRATELLI Current Directory C:\Autodesk\Autodesk_Revit_2014_Brazilian_Portuguese_Win_32-64bit_R1_wi_pt-BR
2014/2/10:21:52:50 Arianne ARIANNEFRATELLI Launch
2014/2/10:21:52:50 Arianne ARIANNEFRATELLI CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_Brazilian_Portuguese_Win_32-64b... /SN 900-32234522 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/10:21:52:50 Arianne ARIANNEFRATELLI Current Directory C:\Users\Arianne\AppData\Local\Temp\_AI290B.tmp
2014/2/10:21:53:39 Arianne ARIANNEFRATELLI === Setup ended ===
2014/2/10:21:52:54 Arianne ARIANNEFRATELLI === Setup started on ARIANNEFRATELLI by Arianne ===
2014/2/10:21:52:54 Arianne ARIANNEFRATELLI Path_Length: 149
2014/2/10:21:52:54 Arianne ARIANNEFRATELLI Current Directory C:\Users\Arianne\AppData\Local\Temp\_AI290B.tmp
2014/2/10:21:52:54 Arianne ARIANNEFRATELLI Launch
2014/2/10:21:52:56 Arianne ARIANNEFRATELLI Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/SETUP_x64.ta...
2014/2/10:21:53:38 Arianne ARIANNEFRATELLI Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/SETUP_x64.ta...
2014/2/10:21:53:38 Arianne ARIANNEFRATELLI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Arianne\AppData\Local\Temp\_AI290B.tmp\Setup\RevitSetup.dll
2014/2/10:21:53:38 Arianne ARIANNEFRATELLI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/10:21:53:39 Arianne ARIANNEFRATELLI PageOpen LaunchDialog
2014/2/10:21:56:54 Arianne ARIANNEFRATELLI PageOpen LicenseDialog
2014/2/10:22:00:10 Arianne ARIANNEFRATELLI PageOpen ProductInfoDialog
2014/2/10:22:00:10 Arianne ARIANNEFRATELLI PageOpen ProductSelectionDialog2
2014/2/10:22:01:15 Arianne ARIANNEFRATELLI PageOpen FullProgressDialog
2014/2/10:22:01:16 Arianne ARIANNEFRATELLI Download Play VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/VCREDIST2005...
2014/2/10:22:01:20 Arianne ARIANNEFRATELLI Download Complete VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/VCREDIST2005...
2014/2/10:22:01:20 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Arianne\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/2/10:22:02:18 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/2/10:22:02:20 Arianne ARIANNEFRATELLI Download Play KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314ATLX...
2014/2/10:22:02:21 Arianne ARIANNEFRATELLI Download Complete KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314ATLX...
2014/2/10:22:02:21 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/10:22:02:29 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/10:22:02:33 Arianne ARIANNEFRATELLI Download Play KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314MFCX...
2014/2/10:22:02:40 Arianne ARIANNEFRATELLI Download Complete KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314MFCX...
2014/2/10:22:02:41 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/10:22:03:00 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/10:22:03:03 Arianne ARIANNEFRATELLI Download Play KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314CRTX...
2014/2/10:22:03:05 Arianne ARIANNEFRATELLI Download Complete KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314CRTX...
2014/2/10:22:03:05 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/10:22:03:19 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/10:22:03:20 Arianne ARIANNEFRATELLI Download Play KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314OPEN...
2014/2/10:22:03:21 Arianne ARIANNEFRATELLI Download Complete KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314OPEN...
2014/2/10:22:03:21 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/10:22:03:34 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/10:22:03:35 Arianne ARIANNEFRATELLI Download Play KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314ATLX...
2014/2/10:22:03:36 Arianne ARIANNEFRATELLI Download Complete KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314ATLX...
2014/2/10:22:03:36 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/10:22:03:45 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/10:22:03:46 Arianne ARIANNEFRATELLI Download Play KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314MFCX...
2014/2/10:22:03:55 Arianne ARIANNEFRATELLI Download Complete KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314MFCX...
2014/2/10:22:03:55 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/10:22:04:10 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/10:22:04:11 Arianne ARIANNEFRATELLI Download Play KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314CRTX...
2014/2/10:22:04:14 Arianne ARIANNEFRATELLI Download Complete KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314CRTX...
2014/2/10:22:04:14 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/10:22:04:26 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/10:22:04:29 Arianne ARIANNEFRATELLI Download Play KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314OPEN...
2014/2/10:22:04:30 Arianne ARIANNEFRATELLI Download Complete KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/KB958314OPEN...
2014/2/10:22:04:30 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/10:22:04:42 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/10:22:04:43 Arianne ARIANNEFRATELLI Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/VCREDIST2005...
2014/2/10:22:04:47 Arianne ARIANNEFRATELLI Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{ECBD9184-4FB4-4D34-8925-263034DDC435}/VCREDIST2005...
2014/2/10:22:04:47 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Arianne\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/10:22:06:09 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/2/10:22:06:18 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/10:22:06:26 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/10:22:06:34 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/10:22:06:40 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/10:22:06:48 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/10:22:06:56 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/10:22:07:04 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/10:22:07:09 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/10:22:07:09 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/2/10:22:07:10 Arianne ARIANNEFRATELLI PageOpen InstallCompleteDialog
2014/2/10:22:09:37 Arianne ARIANNEFRATELLI === Setup ended ===
2014/2/11:23:03:00 Arianne ARIANNEFRATELLI === Setup started on ARIANNEFRATELLI by Arianne ===
2014/2/11:23:03:00 Arianne ARIANNEFRATELLI Path_Length: 149
2014/2/11:23:03:00 Arianne ARIANNEFRATELLI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/11:23:03:00 Arianne ARIANNEFRATELLI Launch
2014/2/11:23:03:00 Arianne ARIANNEFRATELLI CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-32234522 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/11:23:03:00 Arianne ARIANNEFRATELLI Current Directory C:\Users\Arianne\AppData\Local\Temp\_AIA752.tmp
2014/2/11:23:03:05 Arianne ARIANNEFRATELLI === Setup ended ===
2014/2/11:23:03:02 Arianne ARIANNEFRATELLI === Setup started on ARIANNEFRATELLI by Arianne ===
2014/2/11:23:03:02 Arianne ARIANNEFRATELLI Path_Length: 149
2014/2/11:23:03:02 Arianne ARIANNEFRATELLI Current Directory C:\Users\Arianne\AppData\Local\Temp\_AIA752.tmp
2014/2/11:23:03:02 Arianne ARIANNEFRATELLI Launch
2014/2/11:23:03:03 Arianne ARIANNEFRATELLI Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/11:23:03:04 Arianne ARIANNEFRATELLI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Arianne\AppData\Local\Temp\_AIA752.tmp\Setup\RevitSetup.dll
2014/2/11:23:03:04 Arianne ARIANNEFRATELLI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/11:23:03:05 Arianne ARIANNEFRATELLI PageOpen LaunchDialog
2014/2/11:23:05:46 Arianne ARIANNEFRATELLI PageOpen LicenseDialog
2014/2/11:23:08:33 Arianne ARIANNEFRATELLI PageOpen ProductInfoDialog
2014/2/11:23:08:33 Arianne ARIANNEFRATELLI PageOpen ProductSelectionDialog2
2014/2/11:23:08:59 Arianne ARIANNEFRATELLI PageOpen FullProgressDialog
2014/2/11:23:09:00 Arianne ARIANNEFRATELLI Download Skipped KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/11:23:09:00 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/11:23:09:06 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/11:23:09:06 Arianne ARIANNEFRATELLI Download Skipped KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/11:23:09:06 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/11:23:09:16 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/11:23:09:16 Arianne ARIANNEFRATELLI Download Skipped KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/11:23:09:16 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/11:23:09:24 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/11:23:09:24 Arianne ARIANNEFRATELLI Download Skipped KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/11:23:09:24 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/11:23:09:31 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/11:23:09:32 Arianne ARIANNEFRATELLI Download Skipped KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/11:23:09:32 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/11:23:09:36 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/11:23:09:37 Arianne ARIANNEFRATELLI Download Skipped KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/11:23:09:37 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/11:23:09:47 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/11:23:09:47 Arianne ARIANNEFRATELLI Download Skipped KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/11:23:09:47 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/11:23:09:55 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/11:23:09:55 Arianne ARIANNEFRATELLI Download Skipped KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/11:23:09:55 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/11:23:10:11 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/11:23:10:11 Arianne ARIANNEFRATELLI Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/11:23:10:11 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Arianne\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/11:23:11:32 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/2/11:23:11:39 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/11:23:11:47 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/11:23:11:53 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/11:23:11:57 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/11:23:12:03 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/11:23:12:08 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/11:23:12:14 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/11:23:12:18 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/11:23:12:18 Arianne ARIANNEFRATELLI PageOpen InstallCompleteDialog
2014/2/11:23:12:42 Arianne ARIANNEFRATELLI === Setup ended ===
2014/2/12:13:29:27 Arianne ARIANNEFRATELLI === Setup started on ARIANNEFRATELLI by Arianne ===
2014/2/12:13:29:27 Arianne ARIANNEFRATELLI Path_Length: 149
2014/2/12:13:29:27 Arianne ARIANNEFRATELLI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/12:13:29:27 Arianne ARIANNEFRATELLI Launch
2014/2/12:13:29:27 Arianne ARIANNEFRATELLI CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-32234522 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/12:13:29:27 Arianne ARIANNEFRATELLI Current Directory C:\Users\Arianne\AppData\Local\Temp\_AID565.tmp
2014/2/12:13:29:42 Arianne ARIANNEFRATELLI === Setup ended ===
2014/2/12:13:29:32 Arianne ARIANNEFRATELLI === Setup started on ARIANNEFRATELLI by Arianne ===
2014/2/12:13:29:32 Arianne ARIANNEFRATELLI Path_Length: 149
2014/2/12:13:29:32 Arianne ARIANNEFRATELLI Current Directory C:\Users\Arianne\AppData\Local\Temp\_AID565.tmp
2014/2/12:13:29:32 Arianne ARIANNEFRATELLI Launch
2014/2/12:13:29:34 Arianne ARIANNEFRATELLI Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/12:13:29:36 Arianne ARIANNEFRATELLI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Arianne\AppData\Local\Temp\_AID565.tmp\Setup\RevitSetup.dll
2014/2/12:13:29:37 Arianne ARIANNEFRATELLI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/12:13:29:41 Arianne ARIANNEFRATELLI PageOpen LaunchDialog
2014/2/12:13:34:24 Arianne ARIANNEFRATELLI PageOpen LicenseDialog
2014/2/12:13:34:37 Arianne ARIANNEFRATELLI PageOpen ProductInfoDialog
2014/2/12:13:34:37 Arianne ARIANNEFRATELLI PageOpen ProductSelectionDialog2
2014/2/12:13:34:54 Arianne ARIANNEFRATELLI PageOpen FullProgressDialog
2014/2/12:13:34:55 Arianne ARIANNEFRATELLI Download Skipped KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/12:13:34:55 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:13:35:04 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/12:13:35:04 Arianne ARIANNEFRATELLI Download Skipped KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/12:13:35:04 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:13:35:16 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/12:13:35:16 Arianne ARIANNEFRATELLI Download Skipped KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/12:13:35:16 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:13:35:26 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/12:13:35:27 Arianne ARIANNEFRATELLI Download Skipped KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/12:13:35:27 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:13:35:36 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/12:13:35:36 Arianne ARIANNEFRATELLI Download Skipped KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/12:13:35:36 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:13:35:42 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/12:13:35:42 Arianne ARIANNEFRATELLI Download Skipped KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/12:13:35:42 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:13:35:55 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/12:13:35:55 Arianne ARIANNEFRATELLI Download Skipped KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/12:13:35:55 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:13:36:06 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/12:13:36:06 Arianne ARIANNEFRATELLI Download Skipped KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/12:13:36:06 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:13:36:15 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/12:13:36:15 Arianne ARIANNEFRATELLI Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/12:13:36:15 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Arianne\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/12:13:37:53 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/2/12:13:38:06 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/12:13:38:15 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/12:13:38:25 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/12:13:38:31 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/12:13:38:39 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/12:13:38:47 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/12:13:38:56 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/12:13:39:05 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/12:13:39:07 Arianne ARIANNEFRATELLI PageOpen InstallCompleteDialog
2014/2/12:13:45:19 Arianne ARIANNEFRATELLI === Setup ended ===
2014/2/12:21:15:47 Arianne ARIANNEFRATELLI === Setup started on ARIANNEFRATELLI by Arianne ===
2014/2/12:21:15:47 Arianne ARIANNEFRATELLI Path_Length: 149
2014/2/12:21:15:47 Arianne ARIANNEFRATELLI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm
2014/2/12:21:15:47 Arianne ARIANNEFRATELLI Launch
2014/2/12:21:15:47 Arianne ARIANNEFRATELLI CommandLine
2014/2/12:21:15:47 Arianne ARIANNEFRATELLI Current Directory C:\Users\Arianne\AppData\Local\Temp\_AICB92.tmp
2014/2/12:21:16:08 Arianne ARIANNEFRATELLI === Setup ended ===
2014/2/12:21:15:54 Arianne ARIANNEFRATELLI === Setup started on ARIANNEFRATELLI by Arianne ===
2014/2/12:21:15:54 Arianne ARIANNEFRATELLI Path_Length: 149
2014/2/12:21:15:54 Arianne ARIANNEFRATELLI Current Directory C:\Users\Arianne\AppData\Local\Temp\_AICB92.tmp
2014/2/12:21:15:54 Arianne ARIANNEFRATELLI Launch
2014/2/12:21:15:56 Arianne ARIANNEFRATELLI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Arianne\AppData\Local\Temp\_AICB92.tmp\Setup\RevitSetup.dll
2014/2/12:21:15:56 Arianne ARIANNEFRATELLI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/12:21:16:09 Arianne ARIANNEFRATELLI PageOpen LaunchDialog
2014/2/12:21:29:43 Arianne ARIANNEFRATELLI PageOpen LicenseDialog
2014/2/12:21:29:47 Arianne ARIANNEFRATELLI PageOpen ProductInfoDialog
2014/2/12:21:34:36 Arianne ARIANNEFRATELLI PageOpen ProductSelectionDialog2
2014/2/12:21:35:19 Arianne ARIANNEFRATELLI PageOpen FullProgressDialog
2014/2/12:21:35:20 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:21:35:34 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/12:21:35:34 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:21:35:53 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/12:21:35:53 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:21:36:11 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/12:21:36:11 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:21:36:26 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/12:21:36:26 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:21:36:34 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/12:21:36:34 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:21:36:55 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/12:21:36:55 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:21:37:11 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/12:21:37:11 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/12:21:37:26 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/12:21:37:26 Arianne ARIANNEFRATELLI Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Arianne\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/12:21:38:50 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/2/12:21:39:03 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/12:21:39:16 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/12:21:39:29 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/12:21:39:38 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/12:21:39:50 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/12:21:40:03 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/12:21:40:17 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/12:21:40:26 Arianne ARIANNEFRATELLI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
This is the point of failure
"2014/2/12:21:38:50 Arianne ARIANNEFRATELLI Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603"
it's unable to install the ATL security update for Microsoft Visual C++ 2005. This is a pre requisite for Revit. Can you try ininstalling all versions of Microsoft Visual C++ 2005 and re install them from the links below?
Microsoft Visual C++ 2005 SP1 Redistributable Package (x86)
http://www.microsoft.com/en-us/download/details.aspx?id=5638
Microsoft Visual C++ 2005 SP1 Redistributable Package (x64)
http://www.microsoft.com/en-us/download/details.aspx?id=18471
Once that is done try your revit install again.
Can you try to use a browser download of the software using our Virtual Agent (#3) here:
http://upandready.typepad.com/up_and_ready/2013/01/quick-start-downloads.html
After it downloads, delete the C:\Autodesk folder because I don't want to use the streaming downloaded files (Install Now). You may need to do this as well.
