When I was installing the sketchbook designer 2013 it said problem adlmPITValidatekey was not found. What can I do?
Welcome to the Community!
During the installation process for sketchbook designer 2013 you are experiencing a problem/error adlmPITValidatekey was not found. Please try the following solutions:
- Disable your anti-virus software from running during the install.
- Make sure you have administrator rights.
- Make sure you meet all system requirements. http://images.autodesk.com/apac_grtrchina_main/files/sketchbook_designer_2013_system_requirements_en...
- Disable any third party utility from running during the install.
- Try performing another clean install. See Article
How to remove all Autodesk products from a Windows system
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Thank you for contacting Autodesk Product Support.
