Installation & Licensing
printer file paths setup when creating C3D 2012 image?
4 REPLIES 4
wvyhonsky
181 Views, 4 Replies
I noticed that the option to set a new location for the printer file paths when creating an image for C3D 2012 isnt there anymore.  Is there a reason for this?
4 REPLIES 4
TravisNave
in reply to: wvyhonsky
What version are you coming up from?  Windows installed printers have been the norm for quite awhile now.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
wvyhonsky
in reply to: TravisNave
up from 2009.  You're saying to use the windows printers instead of the shared pc3 files?
TravisNave
Correct. That would be my recommendation.
Autodesk Forums:
wvyhonsky
My thougt on that is that every time you select a system printer and make even a slight change to the properties, is wants you to save it as a pc3 file.  I'm sure it will be a cleaner setup using the system printers, but i'm not sure why it always wants you to save it as a pc3 file.
Administrator Productivity
