I have my AutoCAD 2009 permanent license registered on my Dell PC with Windows XP for few years now. I just got an IMAC computer with Windows XP installed on it. I was able to install the copy of the AutoCAD2009 software as a trial version from the DVD media. Then I decided I wanted to transfer my license to that IMAC. Using the portable license utility I exported my license first in source computer (Dell PC) without any problems. It created the plu250 file on my desktop (I was trying to attach this file but apparently forum format does not allow it...).
I copied that file to USB stick.
Then I inserted that stick to IMAC computer running Windows XP. Using the same portable license utility i was trying to import the license using the plu250 file from the USB stick. However this created the error with the following message: " this file is not a valid transfer file. export the file again from the source computer. error code [17.1.04]". When I went back to my source computer I was trying to import back my license from the file I just created, but this generated another error: "the computer identification code contained in this transfer code or file does not match this computer's identification code. Import this license on the correct computer. error code: [17.1.88]". So right now I can NOT use AutoCAD LT on either machine... Please HELP!!!
my computers data is as follows:
source computer (PC) identification code: ZDUC W5RC KZWF QF4F
source computer name: electron-11e149
target computer (IMAC) identification code: LHPP 9TYS PEY7 RFRP
target computer name: imac
license name: Electron Consulting - 83313734
One more thing I was trying to write an e-mail to Autodesk customer support but I only got an automated response basically saying that I need to have a case open otherwise I can not even try to respond to their e-mail. How do I open case? Looks like I am in catch 22...
