Your debug log indicates that the ADSKFLEX vendor daemon is up and being
supported by LMGRD at port 27001. So it may be a matter of how you are
pointing to the server. Try setting the following environment variable on
your workstations:
ADSKFLEX_LICENSE_FILE The value should be 27001@REPDSERVER
Jerry
wrote in message news:5768601@discussion.autodesk.com...
The server is already loaded with other network License (RTRT real time)
which is running on 27000 port, our license file is not working. I have
added port as 27001 as in the attached license file. After this change also
the license file is not working. Here I am attaching Necessary log files for
your reference. Kindly do the needful.
