HI!
I am struggling quite a while but I can’t get any new Autodesk program to work. I already have Revit and Navisworks 2013 installed and everything seems to be OK with them they work properly.
Problems start to appear when I tried to install AutoCad and Showcase. In both cases everything seems to be OK when I install them, but when I try to run them splash screen starts up and then it closes and Error report pops up. No error description is available. I have already tried to uninstall and reinstall booth of them, but without success.
I also tried to run “ShowcaseConsole.exe”. It shows the following error.
Sebastjan
I get the same error when trying any option from the Create tab in Maya 2014 student version.
@iulianvifor1 wrote:I get the same error when trying any option from the Create tab in Maya 2014 student version.
read this: http://area.autodesk.com/forum/autodesk-maya/autodesk-maya-2014/log4cplus-error/
DarrenP
read this: http://forums.autodesk.com/t5/Autodesk-Maya-General/log4cplus-ERROR/td-p/4290303
DarrenP
