Installation & Licensing
Distinguished Contributor
timsparks6941
Message 1 of 9 (178 Views)
ntpclient errors on the license server
178 Views, 8 Replies
01-30-2014 10:23 AM
ntpclient errors on the license server are preventing licenses from being available.
I created a support call and their solution is to totally rebuild the license server.
This can't be option one....ideas?
Tim
TravisNave
Message 2 of 9 (175 Views)
Re: ntpclient errors on the license server
01-30-2014 10:31 AM in reply to: timsparks6941
I doubt it.  Though you can get a 0.0.0 error at the client if the time on the client and the time on the server do not have the same time.  You might check to see what the difference is and correct it.
I'd at least start at the CMD prompt and run W32TM /RESYNC to see if the time corrects itself.
You might also set the NLM up as a time server and sync the clients to it.  That way, even if they are both wrong it should still work.  I've done that before.  :-)
What error are the clients getting exactly?
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
timsparks6941
Message 3 of 9 (173 Views)
01-30-2014 10:41 AM in reply to: TravisNave
I'm assuming that the client error is a standard 'I can't find a license so I'm not going to load' error from Acad. Did not see it. The first time it happened I received a few calls from various locations. It's a GNUL server.
TravisNave
Message 4 of 9 (165 Views)
01-30-2014 12:22 PM in reply to: timsparks6941
Sounds good.  It could also be a latency issue if they are accessing over a WAN.  Might increase the timeout using the FLEXLM_TIMEOUT variable listed here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7574782&linkID=9240617
Have them get you the error next time as it is helpful.
timsparks6941
Message 5 of 9 (160 Views)
01-30-2014 12:33 PM in reply to: TravisNave
As a standard, we have FLEXLM_TIMEOUT set to 1mil..but I will make sure that this user has that var set...could have been missed.
Thanks...
TravisNave
Message 6 of 9 (159 Views)
01-30-2014 12:43 PM in reply to: timsparks6941
Looks like you have a firm grasp on the NLM workings then.
Assuming  your NLM is actually working, you could also check to see if the ports work by testing them in Internet Explorer (only):
http://servername:27000
http://servername:2080
If a connection is being made, then both ports should yield a result similar to the following:
Wê-60Wê-60Wê-60Wê-60Wê-60
If not, then it could be something else blocking it.  It's a quick verification.
timsparks6941
Message 7 of 9 (153 Views)
01-30-2014 12:58 PM in reply to: TravisNave
both ports echo clean
timsparks6941
Message 8 of 9 (152 Views)
01-30-2014 12:59 PM in reply to: TravisNave
but...do these need to echo clean on the server too?
TravisNave
Message 9 of 9 (150 Views)
01-30-2014 01:02 PM in reply to: timsparks6941
It would only need to if the NLM wasn't starting or if you had an ADMS server running Vault and the clients couldn't connect to their Vaults.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
