Installation & Licensing
no serial number on install!
2 REPLIES 2
d.papalia
352 Views, 2 Replies
When I install both revit and autocad 2014, it fails.
I have downloaded and installed autocad 2011 a few years ago and all worked fine.
When I download the student version, before I install it its meant to come up with the product and serial number window?(window 1 attachment)
Mine doesnt open this window. It just starts the install after I have downloaded it. When the install is complete I restart the pc. Once its back on, and open up autocad 2014 and I get this window(issue in attachments). The program crashes and it says it needs to close. I dont get this window either, try activate(image in attachments)
NEED HELP ON HOW TO GET THIS TO WORK AND HOW TO ACTIVATE???????
Cheers
2 REPLIES 2
TravisNave
in reply to: d.papalia
You're probably suffering from a known issue we affectionately refer to as the "2014 activation crash."
See my link below for the fix.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21825687&linkID=12305695
Good luck!
Autodesk Forums:
d.papalia
in reply to: TravisNave
I have followed all the steps on that license crash page, and still doesnt work!!!!!
What else can I do?
Administrator Productivity
