• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    no Host Name or Server Code
    112 Views, 1 Replies
    09-26-2000 11:36 AM
    Removed old server and built new Netware 5.1 server. Tried to install
    Autocad LT 97 using Network Installation guide. Installation appears to go
    fine but when autrhorizing the License Mgr nothing comes up under Host
    Nam,e or Server Code. Any help will be appreciated.
    Please use plain text.
    *milana, jerry
    Re: no Host Name or Server Code
    10-01-2000 12:56 AM in reply to: jpm1145
    You need to manually enter your Netware server name
    in AdLM Admin then hit the "add host" button.  Make sure you enter the
    Netware server name in upper case!  Also, be aware that Netware 5,x servers
    are supported only if IPX is the only protocol running on the
    server.
    jerry milana,
    Autodesk Product Support
    style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
    to go
    under Host
    appreciated.
