• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Active Member
    network license server
    139 Views, 1 Replies
    07-20-2011 11:29 AM
    I am workning with an installation of Autodesk Simulation 2012, operating with a network license.  The network license seems to be accessable from any machine EXCEPT for the machine that is acting as the network license server.  Is there any way to run Simulation from the same machine that is acting as the license server?  I was able to get earlier versions to work on the same machine as the licesne.
    Please use plain text.
    TravisNave
    Re: network license server
    07-20-2011 12:03 PM in reply to: bardwin
    This is most likely due to the fact that the local NLM machine is Windows Vista or Windows 7 and the issue is related to IPv6.
    For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
