Installation & Licensing
network license server on linux
8 REPLIES 8
Message 1 of 9
modulo_architects
8763 Views, 8 Replies
We are trying to install the network license server for the Building Design Suite on a Debian Linux server.  On serverside everything seems to be working, but the clients can't connect to the server.
Has anyone successfully installed the license server on Linux?
Is there a way to troubleshoot al Linux license server?
Is there any documentation on configuring the server on Linux?
8 REPLIES 8
Message 2 of 9
Welcome to the community.
Do you actually have a working adskflex vendor for Linux?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16273721&linkID=9242819
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 9
Yes, we hava a working vendor.  This is the content of the log:
15:58:33 (lmgrd) The license server manager (lmgrd) running as root:
15:58:33 (lmgrd)        This is a potential security problem
15:58:33 (lmgrd)        and is not recommended.
15:58:33 (lmgrd) FLEXnet Licensing (v11.7.0.0 build 73797 x64_lsb)
started on fileserver (linux)
15:58:33 (lmgrd) Copyright (c) 1988-2009 Acresso Software Inc. All
Rights Reserved.
15:58:33 (lmgrd) US Patents 5,390,297 and 5,671,412.
15:58:33 (lmgrd) World Wide Web:  http://www.acresso.com
15:58:33 (lmgrd) License file(s): acad.lic
15:58:33 (lmgrd) lmgrd tcp-port 27000
15:58:33 (lmgrd) Starting vendor daemons ...
15:58:33 (lmgrd) Using vendor daemon port 2080 specified in license file
15:58:33 (lmgrd) Started adskflex (internet tcp_port 2080 pid 31777)
15:58:33 (adskflex) Unable to initialize access to trusted storage: 2
15:58:33 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79971 x64_lsb
15:58:34 (adskflex) Server started on fileserver for:
15:58:34 (adskflex) 65900REVITS_F (consisting of:
85623REVITS_2011_0F
15:58:34 (adskflex) 74200REVITS_2010_0F 60900REVITS_2009_0F
54700REVITS_2008_0F)
15:58:34 (adskflex) PLIST
15:58:34 (adskflex) EXTERNAL FILTERS are OFF
15:58:34 (lmgrd) adskflex using TCP-port 2080
17:06:34 (adskflex) TCP_NODELAY NOT enabled
21:58:33 (lmgrd) TIMESTAMP 8/2/2012
22:03:37 (adskflex) TIMESTAMP 8/2/2012
 3:58:33 (lmgrd) TIMESTAMP 8/3/2012
 4:08:40 (adskflex) TIMESTAMP 8/3/2012
 9:58:33 (lmgrd) TIMESTAMP 8/3/2012
10:13:41 (adskflex) TIMESTAMP 8/3/2012
15:58:33 (lmgrd) TIMESTAMP 8/3/2012
16:18:42 (adskflex) TIMESTAMP 8/3/2012
18:25:46 (lmgrd) Rereading license file... Requested from root@fileserver
18:25:46 (lmgrd) Done rereading
18:25:46 (lmgrd) ...Finished rereading
18:25:47 (adskflex) Rereading license file...
18:25:47 (adskflex) Server started on fileserver for:
18:25:47 (adskflex) 65900REVITS_F (consisting of:
85623REVITS_2011_0F
18:25:47 (adskflex) 74200REVITS_2010_0F 60900REVITS_2009_0F
18:25:47 (adskflex) PLIST
18:25:47 (adskflex) Updating feature 65900REVITS_F
Message 4 of 9
Looks good. When you PING your license manager by hostname (which I believe is fileserver) do you get the proper IPv4 response? Also, are your ports open? The adskflex vendor uses 2080. Typically the lmgrd uses 27000 unless specified otherwise.
Autodesk Forums:
Message 5 of 9
Yes, I can ping the fileserver on the network.  I get an IP4 address in response.  Netstat tells me that both port 2080 and 27000 are open and that these ports are linked tot adskflex and lmgrd.
Is there a way to check the available licenses in Linux?
Message 6 of 9
I am sure there is some sort of lmutil syntax you can use to verify.  However, your log file already shows there are products available.
What error are you getting at the client?
Autodesk Forums:
Message 7 of 9
I don't realy get an error message when I try to connect from the client side:
First a get an window where I can enter the license server name
When I enter 'fileserver' I get the same window again.
This is strange because for any other servername I enter, I get the "could not obtain license error".
Message 8 of 9
I found out that most of our PC's did connect to the new license server.  It seemed to be a local problem on some PC's, including my own.  I reinstalled the building design suite on the affected PC's and everything seems te be working fine now...
The problem is solved.  Thanks very much for your help!
Message 9 of 9
Well done!
Autodesk Forums:
Administrator Productivity
