I was able to install successfully without any difficulty when I install AutoCAD 2012 30 day trial in 2013, last year. And I uninstalled it in order to reinstall 3 year student AutoCAD2012 for class starting from this year. But this time, my pc keeps rejecting. My pc shuts down on the way of installing. One time, PC even showed the error sign and said the software I tried to download is uknown souce. Few things I can think of is.... I might set up securty high without knowing it, or I could not delete previous one completely. I almost emptied inside TEMP file (some are still remaining ) and i tried again, but nothing helped.
Solved by TravisNave. Go to Solution.
Download your appropriate version using the virtual assistant.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
I tried this solution and it doesn't work. I, too, downloaded AutoCAD 3 year student for 2012. I missed the license and serial number on the original download, but captured it on a second download attempt. The method you suggests dowloads to the computer but does not provide serial and ID info. My error message is FAILED for AutoCad and Inventor with no error number. Frustrating.
