Installation & Licensing
multiple copies of licenses in the same license file
3 REPLIES 3
frankieD
187 Views, 3 Replies
I have, as an example, 2 Maya 2012 licenses on 1 server. Because I have 3 departments benchmarking and performing QA work against those 2 license I need to acquire 3-4 more. If I add those new licenses to license server will they hide the first 2 that are listed in the license file on the server. My past experience is that it might.
Frank
3 REPLIES 3
DarrenP
in reply to: frankieD
you would have to regenerate all licenses on the same date
if you don't then yes those 2 licenses will be "hidden"
DarrenP
frankieD
in reply to: DarrenP
Thanks. How do I regenerate licenses? I have not heard of that before. By the way I have licenses through my ADN account if that makes any difference.
Frank
TravisNave
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 2 > (Network)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and ethernet ID of the license server.
www.licenseparser.com > This will break down your current license file into plain english and you will find the serial number there.
Autodesk Forums:
Administrator Productivity
