• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    skr_narva
    mdt 2009 activation
    306 Views, 11 Replies
    05-26-2011 01:50 AM
    step by step we upgraded our software from Autodesk Inventor Professional 2008 to Autodesk Product Design Suite Ultimate 2012. So, now on my new PC I've installed this APDSU 2012 (firstly) and activated it. Then I downloaded MDT 2009 from the http://usa.autodesk.com/adsk/servlet/pc/item?id=13744274&siteID=123112  (which announced to be compatible with APDSU 2012 now) and istalled it also. During installation process I used AIP2009's  serial number. The problem - I cannot pass the activation page - it says "The serial number you entered is not valid. Try again. (1)". What I did wrong?
    Please use plain text.
    TravisNave
    Re: mdt 2009 activation
    05-26-2011 08:09 AM in reply to: skr_narva
    You will need to request a new serial number under Subscription from your 2012 suite.  It's possible that your AIP2009 license was upgraded, crossgraded, expired, changed, etc.
    You should be able to request a previous version for MDT2009 from Subscription or your Reseller.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    10-09-2012 02:03 PM in reply to: TravisNave
    That sounds wonderful, but, what happens if you subscribed, and have ended the subscription. Can you still get an activation for your existing INV2012?  Seems fair? I just moved from xp64 to windows7 because inv2012 hates directx9. So I reformatted, installed inv2012, downloaded MDT 2009 for inv2012. I use my serial for inv2012 and it says my serial number  is invalid. Please help!
    TravisNave
    10-09-2012 02:14 PM in reply to: dwweekly
    That's because to use 2009 (three versions back) it is required that you maintain Subscription. Without it, you cannot use the previous version.
    Travis Nave
    Member
    10-09-2012 02:26 PM in reply to: TravisNave
    My employerhas  been a customer with subscriptions back to when they started subscription
    Probably  bought ver11 of autocad or older!
    They hit a patch of hard times and back off on the subscriptions and now
    We can get licensing for what we paid for already? Is that fair?
    Can someone call me to discuss this please.
    TravisNave
    10-09-2012 02:28 PM in reply to: dwweekly
    You can get licensing for the last available product that was under Subscription.  If that was Inventor 2012, then you can activate 2012.  However, unless you are under Subscription, that will not allow you to also run 2009.  As for calling, you should probably call your Reseller.  This is just a peer support group forum.  We're all in the same boat as you and volunteer our knowledge to help each other out.
    Travis Nave
    Member
    IRe: mdt 2009 activation
    10-09-2012 02:38 PM in reply to: TravisNave
    MDT 2009 is available for support for the legacy of reading old files in the old format. If we were only in autocad and had autocad 2012 you could open a autocad 10-12 file still . MDT2009 is supposed to be available to read old files since they discontined it. That is why it is a free download.  It should install under the existing licence. Autodesk please help!
    TravisNave
    Re: IRe: mdt 2009 activation
    10-09-2012 02:44 PM in reply to: dwweekly
    This is just a discussion group.  Autodesk support is made thru your Subscription portal.  All other support is handled by your Value-Added Reseller.
    http://usa.autodesk.com/adsk/servlet/ps/searchform?id=1088201&siteID=123112
    Travis Nave
    philip.s
    10-09-2012 02:56 PM in reply to: dwweekly
    Hi Doug,
    Confirming that you still have MDT 2009 access based on a valid license of Inventor 2012. As mentioned in this informative MDT Up and Ready blog post, please make sure that you are activating with the Inventor licensing info and not the MDT SN.
    In the event that you are still experiencing issues, please send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with all relevant licensing info and the proper request code.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Member
    10-09-2012 03:09 PM in reply to: philip.s
    Thank you very much, especially for the quick response. I will go over this info, and respond. Thanks again!
