Installation & Licensing
maya 2014 some products failed to install. Help please
1 REPLY 1
jcornelson
889 Views, 1 Reply
2014/2/6:14:54:31 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:14:54:31 Jesse JESSE-PC Path_Length: 151
2014/2/6:14:54:31 Jesse JESSE-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/6:14:54:31 Jesse JESSE-PC Launch
2014/2/6:14:54:31 Jesse JESSE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44896439 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/6:14:54:31 Jesse JESSE-PC Current Directory C:\Users\Jesse\AppData\Local\Temp\_AIECB2.tmp
2014/2/6:14:55:46 Jesse JESSE-PC === Setup ended ===
2014/2/6:14:54:35 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:14:54:35 Jesse JESSE-PC Path_Length: 151
2014/2/6:14:54:35 Jesse JESSE-PC Current Directory C:\Users\Jesse\AppData\Local\Temp\_AIECB2.tmp
2014/2/6:14:54:35 Jesse JESSE-PC Launch
2014/2/6:14:55:27 Jesse JESSE-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/6:14:55:45 Jesse JESSE-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/6:14:55:46 Jesse JESSE-PC PageOpen LaunchDialog
2014/2/6:14:55:53 Jesse JESSE-PC PageOpen LicenseDialog
2014/2/6:14:55:57 Jesse JESSE-PC PageOpen ProductInfoDialog
2014/2/6:14:55:57 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2014/2/6:14:56:01 Jesse JESSE-PC PageOpen FullProgressDialog
2014/2/6:14:56:02 Jesse JESSE-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/2/6:14:56:05 Jesse JESSE-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/2/6:14:56:05 Jesse JESSE-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Jesse\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/6:14:56:37 Jesse JESSE-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2014/2/6:14:56:38 Jesse JESSE-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/2/6:14:57:55 Jesse JESSE-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/2/6:14:57:55 Jesse JESSE-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/6:14:59:32 Jesse JESSE-PC Install DirectX® Runtime Succeeded
2014/2/6:14:59:33 Jesse JESSE-PC Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/6:15:10:03 Jesse JESSE-PC Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/6:15:10:03 Jesse JESSE-PC Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/2/6:15:10:05 Jesse JESSE-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/2/6:15:10:06 Jesse JESSE-PC PageOpen InstallCompleteDialog
2014/2/6:15:10:45 Jesse JESSE-PC === Setup ended ===
2014/2/6:15:13:43 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:15:13:43 Jesse JESSE-PC Path_Length: 151
2014/2/6:15:13:43 Jesse JESSE-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/6:15:13:43 Jesse JESSE-PC Launch
2014/2/6:15:13:43 Jesse JESSE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44896439 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/6:15:13:43 Jesse JESSE-PC An instance of setup is already running. Only one instance of setup can run at a time.2014/2/6:15:13:47 Jesse JESSE-PC === Setup ended ===
2014/2/6:15:15:10 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:15:15:10 Jesse JESSE-PC Path_Length: 151
2014/2/6:15:15:10 Jesse JESSE-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/6:15:15:10 Jesse JESSE-PC Launch
2014/2/6:15:15:10 Jesse JESSE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44896439 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/6:15:15:10 Jesse JESSE-PC An instance of setup is already running. Only one instance of setup can run at a time.2014/2/6:15:15:11 Jesse JESSE-PC === Setup ended ===
2014/2/6:15:18:25 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:15:18:25 Jesse JESSE-PC Path_Length: 151
2014/2/6:15:18:25 Jesse JESSE-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/6:15:18:25 Jesse JESSE-PC Launch
2014/2/6:15:18:25 Jesse JESSE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44896439 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/6:15:18:25 Jesse JESSE-PC Current Directory C:\Users\Jesse\AppData\Local\Temp\_AID118.tmp
2014/2/6:15:18:28 Jesse JESSE-PC === Setup ended ===
2014/2/6:15:18:26 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:15:18:26 Jesse JESSE-PC Path_Length: 151
2014/2/6:15:18:26 Jesse JESSE-PC Current Directory C:\Users\Jesse\AppData\Local\Temp\_AID118.tmp
2014/2/6:15:18:26 Jesse JESSE-PC Launch
2014/2/6:15:18:27 Jesse JESSE-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/6:15:18:28 Jesse JESSE-PC PageOpen LaunchDialog
2014/2/6:15:18:31 Jesse JESSE-PC PageOpen LicenseDialog
2014/2/6:15:18:35 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2014/2/6:15:18:38 Jesse JESSE-PC PageOpen FullProgressDialog
2014/2/6:15:18:38 Jesse JESSE-PC Installing Network License Manager: INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Maya 2014" SETUP_PACKAGECODE={44FFD99B-4877-4732-AA33-2FD3D7B622D2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2014" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/6:15:18:40 Jesse JESSE-PC Install Network License Manager Succeeded
2014/2/6:15:18:40 Jesse JESSE-PC PageOpen InstallCompleteDialog
2014/2/6:15:18:44 Jesse JESSE-PC === Setup ended ===
2014/2/6:15:18:56 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:15:18:56 Jesse JESSE-PC Path_Length: 151
2014/2/6:15:18:56 Jesse JESSE-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/6:15:18:56 Jesse JESSE-PC Launch
2014/2/6:15:18:56 Jesse JESSE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44896439 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/6:15:18:56 Jesse JESSE-PC Current Directory C:\Users\Jesse\AppData\Local\Temp\_AI4A3D.tmp
2014/2/6:15:19:01 Jesse JESSE-PC === Setup ended ===
2014/2/6:15:18:59 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:15:18:59 Jesse JESSE-PC Path_Length: 151
2014/2/6:15:18:59 Jesse JESSE-PC Current Directory C:\Users\Jesse\AppData\Local\Temp\_AI4A3D.tmp
2014/2/6:15:18:59 Jesse JESSE-PC Launch
2014/2/6:15:19:00 Jesse JESSE-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/6:15:19:01 Jesse JESSE-PC PageOpen LaunchDialog
2014/2/6:15:19:06 Jesse JESSE-PC PageOpen LicenseDialog
2014/2/6:15:19:09 Jesse JESSE-PC PageOpen ProductInfoDialog
2014/2/6:15:19:09 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2014/2/6:15:19:37 Jesse JESSE-PC PageOpen FullProgressDialog
2014/2/6:15:19:37 Jesse JESSE-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/2/6:15:19:37 Jesse JESSE-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/6:15:21:21 Jesse JESSE-PC Install DirectX® Runtime Succeeded
2014/2/6:15:21:21 Jesse JESSE-PC Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/6:15:31:50 Jesse JESSE-PC Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/6:15:31:50 Jesse JESSE-PC Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/2/6:15:31:52 Jesse JESSE-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
1 REPLY 1
jessica.t
in reply to: jcornelson
Hello Jesse and welcome to the Autodesk Community!
The 1600 errors can be tough but luckily we have quite a bit of troubleshooting materials to help get you through this. Let's start with these solutions to begin:
Thread One
Thread Two
Thread Three
Please let me know how it goes! If the problem persists please respond to this post with further details. Thank you!
Jessica Thrasher
Administrator Productivity
