2014/2/6:14:54:31 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:14:54:31 Jesse JESSE-PC Path_Length: 151
2014/2/6:14:54:31 Jesse JESSE-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/6:14:54:31 Jesse JESSE-PC Launch
2014/2/6:14:54:31 Jesse JESSE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44896439 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/6:14:54:31 Jesse JESSE-PC Current Directory C:\Users\Jesse\AppData\Local\Temp\_AIECB2.tmp
2014/2/6:14:55:46 Jesse JESSE-PC === Setup ended ===
2014/2/6:14:54:35 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:14:54:35 Jesse JESSE-PC Path_Length: 151
2014/2/6:14:54:35 Jesse JESSE-PC Current Directory C:\Users\Jesse\AppData\Local\Temp\_AIECB2.tmp
2014/2/6:14:54:35 Jesse JESSE-PC Launch
2014/2/6:14:55:27 Jesse JESSE-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/6:14:55:45 Jesse JESSE-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/6:14:55:46 Jesse JESSE-PC PageOpen LaunchDialog
2014/2/6:14:55:53 Jesse JESSE-PC PageOpen LicenseDialog
2014/2/6:14:55:57 Jesse JESSE-PC PageOpen ProductInfoDialog
2014/2/6:14:55:57 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2014/2/6:14:56:01 Jesse JESSE-PC PageOpen FullProgressDialog
2014/2/6:14:56:02 Jesse JESSE-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/2/6:14:56:05 Jesse JESSE-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/2/6:14:56:05 Jesse JESSE-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Jesse\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/6:14:56:37 Jesse JESSE-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2014/2/6:14:56:38 Jesse JESSE-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/2/6:14:57:55 Jesse JESSE-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/2/6:14:57:55 Jesse JESSE-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/6:14:59:32 Jesse JESSE-PC Install DirectX® Runtime Succeeded
2014/2/6:14:59:33 Jesse JESSE-PC Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/6:15:10:03 Jesse JESSE-PC Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/6:15:10:03 Jesse JESSE-PC Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/2/6:15:10:05 Jesse JESSE-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/2/6:15:10:06 Jesse JESSE-PC PageOpen InstallCompleteDialog
2014/2/6:15:10:45 Jesse JESSE-PC === Setup ended ===
2014/2/6:15:13:43 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:15:13:43 Jesse JESSE-PC Path_Length: 151
2014/2/6:15:13:43 Jesse JESSE-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/6:15:13:43 Jesse JESSE-PC Launch
2014/2/6:15:13:43 Jesse JESSE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44896439 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/6:15:13:43 Jesse JESSE-PC An instance of setup is already running. Only one instance of setup can run at a time.2014/2/6:15:13:47 Jesse JESSE-PC === Setup ended ===
2014/2/6:15:15:10 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:15:15:10 Jesse JESSE-PC Path_Length: 151
2014/2/6:15:15:10 Jesse JESSE-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/6:15:15:10 Jesse JESSE-PC Launch
2014/2/6:15:15:10 Jesse JESSE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44896439 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/6:15:15:10 Jesse JESSE-PC An instance of setup is already running. Only one instance of setup can run at a time.2014/2/6:15:15:11 Jesse JESSE-PC === Setup ended ===
2014/2/6:15:18:25 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:15:18:25 Jesse JESSE-PC Path_Length: 151
2014/2/6:15:18:25 Jesse JESSE-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/6:15:18:25 Jesse JESSE-PC Launch
2014/2/6:15:18:25 Jesse JESSE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44896439 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/6:15:18:25 Jesse JESSE-PC Current Directory C:\Users\Jesse\AppData\Local\Temp\_AID118.tmp
2014/2/6:15:18:28 Jesse JESSE-PC === Setup ended ===
2014/2/6:15:18:26 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:15:18:26 Jesse JESSE-PC Path_Length: 151
2014/2/6:15:18:26 Jesse JESSE-PC Current Directory C:\Users\Jesse\AppData\Local\Temp\_AID118.tmp
2014/2/6:15:18:26 Jesse JESSE-PC Launch
2014/2/6:15:18:27 Jesse JESSE-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/6:15:18:28 Jesse JESSE-PC PageOpen LaunchDialog
2014/2/6:15:18:31 Jesse JESSE-PC PageOpen LicenseDialog
2014/2/6:15:18:35 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2014/2/6:15:18:38 Jesse JESSE-PC PageOpen FullProgressDialog
2014/2/6:15:18:38 Jesse JESSE-PC Installing Network License Manager: INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Maya 2014" SETUP_PACKAGECODE={44FFD99B-4877-4732-AA33-2FD3D7B622D2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2014" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/6:15:18:40 Jesse JESSE-PC Install Network License Manager Succeeded
2014/2/6:15:18:40 Jesse JESSE-PC PageOpen InstallCompleteDialog
2014/2/6:15:18:44 Jesse JESSE-PC === Setup ended ===
2014/2/6:15:18:56 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:15:18:56 Jesse JESSE-PC Path_Length: 151
2014/2/6:15:18:56 Jesse JESSE-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/6:15:18:56 Jesse JESSE-PC Launch
2014/2/6:15:18:56 Jesse JESSE-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44896439 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/6:15:18:56 Jesse JESSE-PC Current Directory C:\Users\Jesse\AppData\Local\Temp\_AI4A3D.tmp
2014/2/6:15:19:01 Jesse JESSE-PC === Setup ended ===
2014/2/6:15:18:59 Jesse JESSE-PC === Setup started on JESSE-PC by Jesse ===
2014/2/6:15:18:59 Jesse JESSE-PC Path_Length: 151
2014/2/6:15:18:59 Jesse JESSE-PC Current Directory C:\Users\Jesse\AppData\Local\Temp\_AI4A3D.tmp
2014/2/6:15:18:59 Jesse JESSE-PC Launch
2014/2/6:15:19:00 Jesse JESSE-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/6:15:19:01 Jesse JESSE-PC PageOpen LaunchDialog
2014/2/6:15:19:06 Jesse JESSE-PC PageOpen LicenseDialog
2014/2/6:15:19:09 Jesse JESSE-PC PageOpen ProductInfoDialog
2014/2/6:15:19:09 Jesse JESSE-PC PageOpen ProductSelectionDialog2
2014/2/6:15:19:37 Jesse JESSE-PC PageOpen FullProgressDialog
2014/2/6:15:19:37 Jesse JESSE-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/2/6:15:19:37 Jesse JESSE-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/6:15:21:21 Jesse JESSE-PC Install DirectX® Runtime Succeeded
2014/2/6:15:21:21 Jesse JESSE-PC Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/6:15:31:50 Jesse JESSE-PC Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/6:15:31:50 Jesse JESSE-PC Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/2/6:15:31:52 Jesse JESSE-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Hello Jesse and welcome to the Autodesk Community!
The 1600 errors can be tough but luckily we have quite a bit of troubleshooting materials to help get you through this. Let's start with these solutions to begin:
Please let me know how it goes! If the problem persists please respond to this post with further details. Thank you!
