Hi
I have been running maya 2012 on fedora linux for the last year, no problems
recently I installed maya 2013, again no problems.
then this week I put a new install of the same OS (fedora 14) on my machine, now I get
this error when I try and run maya2013
/usr/autodesk/maya2013-x64/bin/maya.bin: error while loading shared libraries: libcrypto.so.6: cannot open shared object file: No such file or directory
I have maya 2012 working well on the fresh install
I have tried some symlinks I found on the internet but these dont seem to be working
if anyone has any ideas I would love to hear them
best
Tom
PS my install notes below
"_____installing all these is needed for fedora, do this before the installer
yum install mesa-libGLw
yum install csh
yum install libXp libXp-devel
yum install gamin audiofile audiofile-devel e2fsprogs-libs
yum install tcsh
yum install xorg-x11-fonts-ISO8859-1-100dpi
yum install xorg-x11-fonts-ISO8859-1-75dpi
yum install liberation-mono-fonts liberation-fonts-common liberation-sans-fonts liberation-serif-fonts
su -
cd /mnt/bigMan/software/graphics/3D/Maya/linux/2013/Autodesk_Maya_2013_SP1_English_Linux_64bit
./setup
enter serial number etc.
////maybe try to chmod the .bin files
cd /usr/autodesk/maya2013-x64/bin
chmod 777 maya
chmod 777 maya2013
maya
or
./maya
to launch
//if you get.....error while loading shared libraries: libXp.so.6: cannot open shared object file: No such file or directory
yum install libXp
problems with middle mouse button? (when you try and pan with middle mouse?)
(Maya) window->settingAndPreferences>preferences->interface
you'll see an option to enable/disable the mouse scroll wheel.
//problems with the alt key?
might want to look in system>prefs>windows too for alt key behaviour
problems with fonts
system>administration>add remove programs
search for these packages
install them all
there will be problems with the hotkeys and shortcuts (see the apple keyboard section below)
//if there is beef with sound files
yum install audiofile-devel
// and if that doesnt work maybe?
ln -s /usr/lib/libaudiofile.so.0 /usr/lib/libaudiofile.so
______________ copy over the BM UI
// delete all contents of '/home/bmuser/maya' then
cp -r /mnt/bigMan/pipeline/maya/linuxPipe/20111204/* /home/bmuser/maya
______________careful to not overwrite the module for renderman, check it points to the right version still...
/home/starscream/maya/2012-x64/modules
// if maya isnt getting the correct permissions to write preference files etc.. we need to fix that
// -R is recursive meaning it will do all sub-folders
chown -R bmuser /home/bmuser/maya/
chmod 777 /home/bmuser/maya/
_______to make a launch icon
_______copy this command into the 'command' part of the preferences for the icon
_______selinux has been known to cause libcrypto probs before, so just check its turned off if we are having some beefs "
