• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    superflash43
    maya 2012 installer saying that maya is already installed
    70 Views, 1 Replies
    02-08-2012 01:58 PM
    currently im trying to install autodesk maya 2012 student edition and when you choose what parts to install it says maya is already installed when its not
    i had installed this a while back but i uninstalled it
    not sure what to do
    ***Guru
    TravisNave
    Re: maya 2012 installer saying that maya is already installed
    02-08-2012 02:04 PM in reply to: superflash43
    To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
    http://support.microsoft.com/mats/Program_Install_and_Uninstall
    For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
    For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
