Installation & Licensing
Active Member
cepegra
Message 1 of 12 (1,881 Views)
maya 2011 server license
1881 Views, 11 Replies
06-15-2010 01:45 AM
I have a license server with Version 11.7 for lmgrd.
In my PC I install and modfy the env with network in place of standalone. I have no LICPATH.ENV in my PC. I have no flexnet folder or *.pit in Adlm folder.
I receive a message after giving the server name. I receive no licence.
Product Support
Message 2 of 12 (1,859 Views)
Re: maya 2011 server license
06-16-2010 03:51 AM in reply to: cepegra
To Receive license you will need to contact Activations Team at the Autodesk Business Center.
Contact information for various regions is below :
Americas
Opening hours Monday through Friday, 8:00 AM - 8:00 PM EST
Email: authcodes@autodesk.com
Phone: toll free 800-551-1490 or 415-507-4690
Fax: 800-225-6490
Europe and Middle East
Opening hours Monday through Friday, 8:00 AM - 6:00 PM CET
Email: authcodes.neu@autodesk.com
Fax: +41 32 723 9169
Asia Pacific
Opening hours Monday through Friday, 9:00 AM - 6:00 PM Singapore TimeEmail: ap.register@activation.autodesk.com
Japan
Email: japan.register@activation.autodesk.com
Fax: 03-6221-1791
Once you receive the lciense you follow this video to setup the license server.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14079851&linkID=9242258
Assuming that your license server is up and running and you have maya license available. and as you mention that  you have edited your license.env file and have changed it from standalone to network. You will need to create maya.lic file in C:\flexlm.
Content of Maya.lic
SERVER <Machine name or IP address of license server> 0
USE_SERVER
Start Maya
Hope that helps
Anil Choudhary
Product Support Specialist
Active Member
cepegra
Message 3 of 12 (1,856 Views)
06-16-2010 03:57 AM in reply to: anil.choudhary
I have the licence from autodesk. It is my local server that does'nt deliver licence.
Product Support
Message 4 of 12 (1,845 Views)
06-16-2010 07:13 AM in reply to: cepegra
Thanks for the update.
Do you have Maya.lic in the c:\flexlm.
if yes can you edit and use IP address instead of machine name.
Can you post your debug.log file.
In Lmtools under server status can you do a Perform Status Enquiry and post it.
Do you have firewall, can you temporarily turn off and try starting Maya.
Firewall Port and Application Exceptions
Ports:  TCP  ports 2080 and 27000-27009
Applications: adskflex.exe and lmgrd.exe
I just saw in your message that you do not have .pit file in ADLM. You might want to uninstall Maya and reinstall it again  as network license so that all the necessary files are created.
Anil Choudhary
Active Member
cepegra
Message 5 of 12 (1,834 Views)
06-16-2010 11:43 PM in reply to: anil.choudhary
I have no folder flexlm...
When I install Maya 2011, I must choose between try or enter a key. Before, in Maya 2010, I can tick use a server. That option doesn't appear...So I modify the licence. env with network in place of standalone.
I don't use the firewall because myserver and my PC are in the same network.
Here is the status enquiry.
Product Support
Message 6 of 12 (1,828 Views)
06-17-2010 12:27 AM in reply to: cepegra
While installing you will you will come configure button where you can specify network by default it is standalone.  Attached Screen shot.
Can you create a Flexlm folder in C:\ and create a Maya.lic file and its contents.
Content of Maya.lic
USE_SERVER
save and start Maya.
If you get error can you post your debug .log (File that you specified in LMtools as log).
Anil Choudhary
Active Member
cepegra
Message 7 of 12 (1,823 Views)
06-17-2010 02:16 AM in reply to: anil.choudhary
That doesn't function.
I send the error message in the PC and the licence.lic.
Product Support
Message 8 of 12 (1,814 Views)
06-17-2010 03:34 AM in reply to: cepegra
To avoid all these errors, I would suggest that you uninstall maya and reinstall as a network and all the required files are automatically created.
You can try this first before doing the Uninstall and reinstall.
Autodesk Maya uses Maya.lic license file on the client machine to look for the license from the License server, Did you create a flexlm folder in C:\  If not  Can you create a Flexlm folder in C:\ and create a Maya.lic file and its contents.
Content of Maya.lic (Use Notepad to type) (Do not use .txt extension)
SERVER < IP address of license server> 0
USE_SERVER
If you get error can you post your debug .log (File that you specified in LMtools/ Config tab, Path to debug log).
I have attached  a doc  for setting  a environment variable, this is not required if you have maya.lic file.
Anil Choudhary
Active Member
cepegra
Message 9 of 12 (1,809 Views)
06-17-2010 04:47 AM in reply to: anil.choudhary
I had already reinstall in network mode before posting the last post.
There is the log
Product Support
Message 10 of 12 (1,789 Views)
06-17-2010 11:35 PM in reply to: cepegra
Thanks for the log file, It cleared all my douts. Your earlier attachment shows that you are trying to run Maya 2011.  your log file do not show any trace of Maya 2011 license.
You will need to contact ABC (Autodesk business centre) to get the updated license.
Pls If you already have Maya 2011 license you will need to replace your current license with new one.
you can post your license file for me to check.
Anil Choudhary
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
