• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    linux file server
    89 Views, 1 Replies
    07-07-2000 03:15 PM
    we just upgraded to a linux server running Samba on Netmax. Everything works very good except that with autocad 2000 when a file is saved it converts the file name to all to upper case text (hard to read with long file names). With our Windows NT Server this obviously didn't occur. We are running Windows 2000 Professional on the workstation. Is this a problem that can be fixed through autocad? It doesn't occur with any other programs like Microsoft Word or Excel, etc... only Autocad 2000.
    Please use plain text.
    *milana, jerry
    Re: linux file server
    07-11-2000 10:36 AM in reply to: sirhaljj
    The reason AutoCAD does this and not most other applications is that
    AutoCAD's SAVE routine works different. Most applications simply open a file
    to write and close it when you are done. AutoCAD places a lock on the file
    you "open" and creates a working copy of the file. When you do an AutoCAD
    save, the lock on the dwg file is momentarily released, the file deleted and
    the working file is copied to the dwg name. This is where the uppercase
    thing happens. We have a technical document published on this behavior of
    Samba, you can download it at
    http://www3.autodesk.com/adsk/support/techdoc/0,,114640--125452-0_21843,00.h
    tml
    That should fix things for you.
    jerry milana,
    Autodesk Product Support
    "sirhaljj" wrote in message
    news:ef2965e.-1@WebX.SaUCah8kaAW...
