Installation & Licensing
licensing and tech compliance
4 REPLIES 4
736 Views, 4 Replies
we are using these products:
DWF Composer 2.0
DWG to PDF Converter 2005
DWG TrueView 2.0
DWG TrueView 2009
on desktop machines that may be migrated from physical to VDI.  Are there tech or licensing issues we need to be aware of?
4 REPLIES 4
TravisNave
Technically speaking, I don't think Autodesk supports those products in a virtual environment.  However, per license compliance, it shouldn't be a problem if you continue to follow the EULA guidelines.
Autodesk Forums:
in reply to: TravisNave
thanks
tthames
Trying to obtain recommendations for AutoCAD Lt 2012 DWG to PDF converter?
TravisNave
AutoCAD publishes natively to PDF. You don't need a converter. It's built in.
Autodesk Forums:
Administrator Productivity
