• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    licensing Transfer Utility AutoCAD LT 2013
    215 Views, 1 Replies
    12-01-2012 08:13 AM
    I already have a license and AutoCAD LT 2013 installed on the main PC and want to install the back up onto a new PC. I exported the licence from the old back up PC and have istalled a trial version on the new back up but I cannot find the License Transfer Utility. What have I done wrong or not done correctly?
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: licensing Transfer Utility AutoCAD LT 2013
    12-03-2012 02:08 PM in reply to: brianabbey
    The EULA already allows for you to have a backup activation for a laptop or other 2nd device.  You simply need to reactivate both of your installations and you will be good to go.
    Please call Autodesk Product Registration and Authorization:
    http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
    1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
    Asia / Pacific: 65.6735.5688
    Europe / Middle East / Asia: 41.32.723.9595
    You will need to provide your serial number and the request code.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
