Installation & Licensing
license transfer problem
5 REPLIES 5
273 Views, 5 Replies
I use autocad 2002. I exported my computer licence to another computer. on target computer I have imported license.ctl file . but autocad does not work. autocad portable license utily program on target pc shows error which is in attached file (pls see.) I exported license from my computer two times and imported on target pc. but It says license broken. what should I do?
5 REPLIES 5
I can still export license from source pc to target pc. it works. how can I re transfer license to source computer. I tried to transfer license from target pc to source pc. but export button is not active
What error do you get when you try to start AutoCAD on the target computer? -- Jerry Milana, Autodesk Consulting "koc" wrote in message news:40627971_3@newsprd01... > I can still export license from source pc to target pc. it works. how can I > re transfer license to source computer. I tried to transfer license from > target pc to source pc. but export button is not active > >
on target pc, "important. in order to continue you must obtain additional authorization. Error [4]
You should be guided through a process where you are presented with a "Request Code". Contact your dealer to get a repair code, they will need your serial number and request code. Once you have fixed your license on the target you can export it back to the original PC. -- Jerry Milana, Autodesk Consulting "koc" wrote in message news:40628bb3_2@newsprd01... > on target pc, "important. in order to continue you must obtain additional > authorization. > Error [4] > >
This error indicates that the license files have been deleted on this PC. For AutoCAD 2002, they are stored in the hidden folder C:\C_DILLA. You must not change anything in this folder, or else you will have to reauthorize. Broken licenses must be fixed by getting a new auth code on the PC where the license now is. Then you can use the license or re-export it. You can't fix a license by trying to import again. --Cy-- "koc" wrote in message news:40628bb3_2@newsprd01... > on target pc, "important. in order to continue you must obtain additional > authorization. > Error [4] > >
Administrator Productivity
