• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    jbayne
    Re: license manager not releasing licenses timely
    09-27-2012 05:39 AM in reply to: TravisNave
    We are rather new at Revit and the lic manager. I am having the same troubles as listed above. Is this still an ongoing problem?
    We are running LMTOOLS Ver. 11.7.0.0 Build 73797 i86 _n3
     Because we have a very stingy IS dept I do not have access to the server that the lic man resides on. About once a month I have to call IS to have them do a Stop and Start on the manager. Is there a way I can avoid this?
    Please use plain text.
    *Expert Elite*
    TravisNave
    10-03-2012 02:11 PM in reply to: jbayne
    You can access your NLM remotely thru a local LMTOOLS on your workstation by choosing configure with license file and placing 27000@SERVERNAME in the box.  Servername is the hostname of your server.  That will allow you to remotely administer the server.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
