Thanks for the information guys.
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
"Jimmy Bergmark" wrote in message
news:40881d08$1_3@newsprd01...
> In my experience the ports are taken from 27000 and up in the order that
you
> start the services unless you have specified the port in the license file
> using TCP:27000 on the SERVER line.
> Best Regards, Jimmy Bergmark
> CAD and Database Developer Manager at www.pharmadule-emtunga.com
> Take a look at
> JTB FlexReport (FLEXlm report tool) - www.jtbworld.com/jtbflexreport
> SmartPurger (Purges automatically) - www.jtbworld.com/?/smartpurger.htm
> or download some freeware at www.jtbworld.com
> More on AutoCAD 2005;
> www.jtbworld.com/autocad2005.htm
> "Jon Rizzo" wrote in message
> news:40881372_3@newsprd01...
> > Does the AutoCAD version determine which ports are used? We have
AutoCAD
> > 2002 and 2004 running (soon to be only 2005).
> > LMTOOLS says that the version is 8.3c, but I don't know if this refers
to
> > the actual license manager, or just lmtools itself.
> > Does this mean it should be using ports 2080 and 27000-27009?
> > Jon Rizzo
> > "jerry milana" wrote in message
> > news:4087fd8e$1_3@newsprd01...
> > > What products and versions are you using? Products prior to AutoCAD
> 2002
> > > used UDP 1422. Our FLEXlm implementation which is used from AutoCAD
> 2002
> > > on, uses TCP packets 2080 and 27000-27009
> > > Jerry Milana,
> > > Autodesk Consulting
> > > news:4087f20b_3@newsprd01...
> > > > We have a strange situation here. We have several subnets in the
> > office,
> > > > and from what I understand, each blocks UDP packets from the others.
> As
> > a
> > > > result, a workstation in our office can only get a license from the
> > > license
> > > > manager while the firewall client is enabled on the workstation. We
> > would
> > > > prefer to not have license manager traffic routed through the
firewall
> > if
> > > we
> > > > can avoid it.
> > > > Is there something we can do to stop the routers from blocking the
> > license
> > > > manager traffic without letting all udp traffic through? (such as
> > opening
> > > a
> > > > specific port to domain users).
> > > > Thanks in advice for any suggestions you may have.
> > > > Jon Rizzo
